Old 10-20-2015, 09:22 AM   #1
our wolf13
Send a message via MSN to ourwolf13 Send a message via Yahoo to ourwolf13
My 19wp fresh water tank
Help me focus, I bought a 2011 19wp and I can't find the fresh water tank drain. I have found the hot and cold water line drains but can't seem to locate the tank drain.
ourwolf13 is offline   Reply With Quote
Old 10-20-2015, 12:57 PM   #2
rmac04401's Avatar
They are usually underneath the drivers side by the axel. On my 26 rr I have to almost crawl under the trailer behind tire to take cap off.
2016 Grey Wolf 26rr
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 10-20-2015, 04:17 PM   #3
Sockman's Avatar
Crawl under it. Mine is closest to the left side, behind the two left side wheels (but mine is a 100 gallon tank, so might be different than yours).
2011 Wolf Pack 19DFWP
Sockman is offline   Reply With Quote
Old 10-23-2015, 03:27 PM   #4
It should be underneath, pretty close to where you fill the fresh tank.
The Hot and Cold water drains you are talking about are the low point drains. After you drain the low points, you still have to do something. Either blow the lines out and/or run some antifreeze through them. DO NOT put antifreeze in the fresh tank! Not sure why people do that, I never saw a post telling to do that...
Steve
Golden CO
2016 Grey Wolf 26RR Limited
92 GMC K2500 454
2006 Honda Rubicon ATV
zuterbru is offline   Reply With Quote
fresh water, tank, water, water tank
