Old 05-21-2018, 11:25 AM   #1
My slide is tearing up the vinyl
I have a Grey Wolf 29BH and the center of the slide is tearing up the vinyl floor while closed.
The vinyl in that area has been getting bunched up and now there is a small tear in the vinyl.
What can I do to prevent further damage?
rfaulkner99 is offline   Reply With Quote
Old 05-22-2018, 08:01 AM   #2
SeaDog's Avatar
The first thing I would do is make sure the slide when closed is square to the rig. From your description it sounds like it may be out at the bottom an in at the top as viewed from outside. Check that and have it adjusted to have the slide parallel to the rig.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 05-31-2018, 05:47 PM   #3
Not the same trailer but I have a vengeance 311a13 that did the same thing. Dealer pulled the slide and there was a ďextraĒ piece of wood under the slide causing the issue, dealer fixed the slide and put a new floor in my trailer
Campingnut86 is offline   Reply With Quote
Old 05-31-2018, 05:54 PM   #4
western NC mountains!
formerFR's Avatar
yep, ours did this early on, and CW found one of our picture frames stuck under the slide, it caused the slide to 'lean' to far forward when coming in, touching the flooring.
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 200w/10amps mobile SOLAR
85,000+mi, US, Alaska, Canada, western NC for now : )
formerFR is offline   Reply With Quote
slide
