Old 04-24-2016, 12:55 PM   #21
On the frig, there is a reset on the chimney.
Name:	Refrigerator high temp stack sensor.jpg
Old 04-24-2016, 01:33 PM   #22
Thanks for the help. It was icing up going through ducts and when I had the vent open to cabin. Could the coils be clogged
drb1984 is offline   Reply With Quote
Old 04-24-2016, 01:45 PM   #23
crunchman12001's Avatar
Yes, with ice. Let it thaw out. How long is your trip?
2015 F-250 FX4
Old 04-25-2016, 07:55 PM   #24
Sorry to hear that. Where are you?
I was at River Ranch this weekend and the A/c did good. Be interested to see what the issue is. As you know I also have a 26rr
2016 Grey Wolf 26RR
2013 GMC Denali 2500 HD
Vero Beach, FL
Vero Beach, FL
jbeal43 is offline   Reply With Quote
Old 04-25-2016, 08:03 PM   #25
Meant the fridge and freezer worked well...I never had my a/c below 72. Temps were in low 80's .
2016 Grey Wolf 26RR
Vero Beach, FL
Vero Beach, FL
Old 04-25-2016, 08:21 PM   #26
deartruc's Avatar
Ok, so definitely iced and thawing should get you back. Catch 22 on how cold you can get the camper. A dehumidifier may help since there would be less humidity to freeze.
One of the mods I saw here was to add pc cooling fans to the fridge external coils which I may try this year. My kids don't like melted Freeze Pops
2017 GMC Yukon
2018 Roo 23 ikss
deartruc is offline   Reply With Quote
Old 04-25-2016, 10:08 PM   #27
That may be something you want dealer to look at under warrantee. My brothers kept freezing up and he had defective AC. The dealer replaced the whole unit.
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2020 Ram 2500 Crew cab 6.5 bed
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 04-25-2016, 10:34 PM   #28
Thanks for all the help. I'm back home and ac and fridge is working great in my driveway. So I'm at a loss. I was at fish eating creek in palmsdale. Had a good weekend besides those issues.
Old 04-26-2016, 01:59 PM   #29
All AC Systems need to cycle on and off to work efficiently. If you have your AC set so low that it can never get to that temp, and the compressor never turns off, it will most likely ice up. Set the temp so the Compressor cycles on and off, turn down a couple of degrees and run for awhile, if it does not cycle, well you have to live with the slightly higher temp. It can also be low on Freon, that causes icing as well. But, trying to make the temp lower than it is capable of is far more common.
Steve
Golden CO
2016 Grey Wolf 26RR Limited
92 GMC K2500 454
2006 Honda Rubicon ATV
zuterbru is offline   Reply With Quote
