Old 08-13-2015, 10:42 AM   #1
New 19v
I just recently bought a new Vengeance 19v. What are some modifications that I should do? Im also having trouble with the keyless entry. I am able to lock it using the keypad, but I cant get it to unlock. HELP!
kogden is offline   Reply With Quote
Old 09-14-2015, 09:38 AM   #2
Still no luck getting it to unlock when the door is closed. It will unlock when I am holding the door open though.
Old 09-14-2015, 05:47 PM   #3
Try pushing the door in to unlock it. It is most likely binding, which is why it works when the door is open. Try to find out why it is binding and adjust it, if you can, so it does not.
zuterbru is offline   Reply With Quote
Old 09-15-2015, 06:03 PM   #4
Ok so that worked when I pushed on it. But I had to put all of my weight on it. That isn't going to work for me.
Old 09-16-2015, 03:54 PM   #5
That means it is binding. Is there a way to adjust it?
You might try loosening the mounting bolts, move to whatever side will loosen it up, and tighten them down.
Is there an adjustment on the striker plate?
Might take a look at that too.
If nothing else, filing down the striker plate will loosen it up.
Steve...
