Well, we just put a deposit on a 2020 25PACK12 Friday, should be picking up sometime the 1st week of June. Has anyone through bolted a motorcycle chock in the toy area, are their any tanks below I need to watch before I drill. I'll be crawling under once I'm home, but just wanted to see if anyone has already done it.
You won't be able to see anything underneath the unit unless you remove the underbelly. I can tell you there is a plywood floor and "joists" under the rubber flooring in the garage.
