Originally Posted by ruddie66
Thanks, I have seen his post on that. Just saw yours and thought you had another option. I'm more than likely will use his same set up somewhat.
Sorry I couldn't help you any better ~ when I had the bike, I was actually going to use rmac's method for the front wheel chock as it was most reasonable and the easiest for me to copy. Now with a trike, I'm completely different from everyone else, a front wheel chock is useless.
Originally Posted by RiderBloke
I installed two extra rings in my floor and use them to anchor my Harbor Freight chock. They are bolted into the under floor stringers - which take a little careful measuring to find. The front wheel is right over the rear axle and only the rear seats and table are rendered unusable when the bike is in. There are photos in some of my prior posts.
Same here RB with tie down location. I took the road side bench completely out, installed another set of straps to the curb side bench (lower end attached to the hinge board and then attach to ring on the wall), allows me to put bench cushion underneath and pull the entire bench tighter to the wall. Got rid of the OEM table and use a folding table with 2 folding chairs, more room and don't need the extra bed.
With the trike, front wheel over the front axle, puts motor over rear axle and heavy rear end just aft, nice balance. 2 MAJOR straps from the rear tie downs to the front engine guards (1 to each side) and then 2 straps from under the rear, crisscrossed underneath to the center tie downs (keeps the rear from dancing sideways). Can still get to sink (barely), but from the fridge forward, no problems.
I worry about things moving when/if I have a panic stop, not the lightening take off!!
