Old 11-17-2015, 03:48 PM   #1
New Guy 2016 26RR
MY wife and I just ordered a 26RR, and pick it up in North Carolina next Wednesday. I guess it is our Thanksgiving present. I am sure I will be using some of the ideas I have seen on here. I have a 2015 Goldwing that has been lowered 1 1/4", so I am sure I will need a ramp mod. My wife has a Suzuki S40. I am confident I can get both bikes in, I just need to figure out the best deal for the chocks without drilling in the floor. I have seen a few of the ideas on here, but haven't figured out which one I like best yet. Chime in with your opinions if you would like.
James15 is offline   Reply With Quote
Old 11-17-2015, 05:09 PM   #2
Welcome from Wisconsin and congrats on your new 26RR.
Old 11-17-2015, 07:08 PM   #3
Cuzdog's Avatar
I did not want to make new holes so I went with what was provided. Pretty much places the bike right over the axels and can still get in the bathroom and fridge.Click image for larger version
Name:	ImageUploadedByForest River Forums1447808877.096618.jpg
ID:	94495Click image for larger version
2015 26RR
2013 F150 5.0
2011 Harley Touring
Cuzdog is offline   Reply With Quote
Old 11-17-2015, 07:36 PM   #4
How is your chock secured?
Old 11-17-2015, 07:45 PM   #5
Cuzdog's Avatar
Aluminum angle bolted to a harbor freight chock, slots cut in the end of the angle to slip over the D rings. Hook the tie downs in the d ring and keeps the angle from moving. I place cheap mats under the chick to protect the floor. Have a couple thousand miles hauling this way with no issue.Click image for larger version
Name:	ImageUploadedByForest River Forums1447811031.076855.jpg
2015 26RR
2013 F150 5.0
2011 Harley Touring
Old 11-17-2015, 07:45 PM   #6
rmac04401's Avatar
New Guy 2016 26RR
Welcome. Here is my set up
Name:	ImageUploadedByForest River Forums1447811090.453359.jpg
ID:	94497Click image for larger version
Name:	ImageUploadedByForest River Forums1447811115.351623.jpg
No movement and stores in nice tiddy spot.
2016 Grey Wolf 26rr
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 11-17-2015, 08:06 PM   #7
Originally Posted by Cuzdog View Post
Aluminum angle bolted to a harbor freight chock, slots cut in the end of the angle to slip over the D rings. Hook the tie downs in the d ring and keeps the angle from moving. I place cheap mats under the chick to protect the floor. Have a couple thousand miles hauling this way with no issue.Attachment 94496
I will probably "borrow" your idea. I like that setup. If it will hold a Harley touring, it will hold a Goldwing. They are about the same weight.
Old 11-17-2015, 08:36 PM   #8
Cuzdog's Avatar
View loaded from the end. I no longer use the back tie downs, think it was nervous first time overkill.Click image for larger version
Name:	ImageUploadedByForest River Forums1447814172.453367.jpg
2015 26RR
2013 F150 5.0
2011 Harley Touring
Old 11-17-2015, 11:08 PM   #9
Usually Confused Member
emm-dee's Avatar
I used the Titan chock. It uses a small plate attached to the floor with two lag bolts. It takes about 30 seconds to remove the chock and the attaching plate is then hidden under the swivel chair. The Titan holds the bike upright and the forward and aft straps pull against each other to keep the bike/chock from moving forward or back.
The front wheel is slightly forward of the trailer rear axle so that's supposed to actually reduce hitch weight a little. Will get it weighed again next week to find out if that's true.
Here's a pic (and maybe someone can explain to me why a pix uploaded from Dropbox gets rotated 90 CCW. ????) http://www.forestriverforums.com/for...1&d=1447823515
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
Old 11-18-2015, 04:56 PM   #10
I did not want to make new holes so I went with what was provided. Pretty much places the bike right over the axels and can still get in the bathroom and fridge.Attachment 94495Attachment 94495
I have the same chock but have problems getting the bike out of it while unloading. What do you do to help with that?
Rhoadzie is offline   Reply With Quote
