Originally Posted by RiderBloke
I'm a very slow worker.
I posted the final result somewhere else - I should have consolidated all my modification posts into one long topic.
Anyway my cupboards are in but not yet used. There are also no latches or struts on the doors as there is a small design difficulty there which I have yet to solve.
Also underneath I have put a set of 5 LED lights from Sam's club and the are self powers, color changeable, and remote controlled. (No photo yet)
I have also just assembled a storage set from Sam's club - $109.99 complete with storage boxes - to go on the RH side when I remove the seat unit. I will probably put a ⅜" plywood back on this unit and screw it securely to the wall. It is to be positioned to leave room for the motorcycle straps from the two D rings to the bike. On either side I may end up having some way to secure a chair etc for use with the Walmart table we have.
The LH seat will also be replaced with a seat unit that will pull out to a full sized bed. I hope it will also be more comfortable as a couch than the present unit. There will be some storage underneath also of course. This is the sort of construction I intend to use.
I've a little work to do in the basement after the flood and an awning motor to replace on the RV so there are projects still to keep me happy until I go to Habitat in Dade City in November.
