Old 06-03-2018, 09:20 AM   #11
Originally Posted by Matt sr View Post
Sorry 4 the delay,Ford 350 extended cab 4x4 off road package diesel auto trans 8' box,some one told me if my sway bar bushings in trk.is worn that will cause it..any one ever hear of this?
You can hop under the truck without putting it on jackstands and see what the condition of the sway bar bushings are. I would say that's likely not the problem. Are you pulling with anything in the tanks? Is the trailer level when pulling? Are you still running the original tires? What's the tire pressure in the trailer tires?
Getting the trailer axles aligned will also help with pulling the trailer straight. I know mine are off because of the tire wear I just need to find a shop that can do the alignment.
blackseven is offline   Reply With Quote
Old 06-03-2018, 10:07 AM   #12
Trailer has 1"lean forward from rear to front of frame,yes tanks empty, except 30 gal gas tank to run generator, camper tires @80psi only have 2 trips on them, roughly 80miles both camping trip...thinking maybe it's them Castle Rock tires???read so much bad about them.
Matt sr is offline   Reply With Quote
Old 06-18-2018, 08:08 PM   #13
I lowered my hitch so I'm nose diving 1"-2",solved all my sway problems! Thanks to all that suggested ideals to try.also by doing this I noticed it was now setting my truck suspension on the helper spring..pulled n rode excellent.
Old 06-28-2018, 10:46 AM   #14
Rsgtivr6's Avatar
Haven't checked back in recently, it's been a busy summer so far.
I read a propane line horror story from a blow-out somewhere, also. I see all the stuff ran under the wheel wells. I will definitely have to come up with some protective measures there.
I don't get any sway, but I do have a good bit of bucking from the camper. pretty much any bump in the road translates back to the hitch. That's the only towing issue i have noticed so far.
The only real gripe we have had so far is the hopeless touch-pad thermostat. Any way to change this to the old button style Dometic?
Otherwise, we have camped a couple times so far and it has been a very good trailer. I, too, wish we had the couch vs the dinette. I think we might try to trade it out, but it's livable for now.
So far, so good! Thanks for the replies!
TV: '17 Ram 2500 Big Horn CCSB CTD 4x4
TT: '18 Wolf Pack Limited 325Pack13
Tow Acc: Andersen Ultimate Hitch 2 goose ball mount, AirLift 5000 bags and HD compressor system
Rsgtivr6 is offline   Reply With Quote
Old 07-10-2018, 10:36 AM   #15
Whats wrong with the dinette?
tom_bergstrom is offline   Reply With Quote
Old 07-10-2018, 02:32 PM   #16
We just picked up a 24PACK14+ the week before Memorial Day. Just got to use it for the first time last week. A very definite upgrade from the pop up I've had for the last 15 years.
smkauffman is offline   Reply With Quote
Old 07-11-2018, 02:28 PM   #17
Rsgtivr6's Avatar
The cushions are only slightly better than sitting on the bare plywood. I miss the couches in the last two for comfortably sitting and talking or watching TV. We already have the rear dinette in the garage (with more comforable bench/couches). Don't need 2.
Old 07-11-2018, 02:42 PM   #18
rmac04401's Avatar
Replace with recliners!!!!
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 07-11-2018, 05:59 PM   #19
Are they offering 7k axles now
I thought they only made them with 6k axles
Whats does your carrying capacity sticker state
Aztec1382 is offline   Reply With Quote
Old 07-12-2018, 08:47 AM   #20
Rsgtivr6's Avatar
I would bet you can custom order with 7k, but mine are 6k. I am 12k dry and 14k GVRW with about 2k pin.
