Old 02-23-2015, 01:32 PM   #641
Toby's Avatar
Don't know about yours or it being 12X12. Maybe 6X6. Mine had one above the entertainment center and one in the bedroom way up high above the bunk and close to the wardrobe. If I would of mounted it there, you'd never be able to see it. Might be better without a bunk. I never used the one in the bedroom. We also put a stand up by the bed and used that. It came with a 300lb table which we put at the foot of the bed. Worked good there.
In my 25RR, my backer plate was not attached to anything of structure. I hope that is a fluke. It was just secured to the false panel that the TV was on. I took the cabinet apart and put some support in there so I could use a swivel mount. It wasn't easy to see the tv in the corner with it flat on the wall.
2018 Ford F250
2019 Arctic Wolf F295QSL8
Toby is offline   Reply With Quote
Old 02-23-2015, 01:55 PM   #642
Mine does not have any mounts in. Back in the corner by the entertainment area there was a picture of Cherokee trailers. I took that off and there was a sticker on the wall that's sad 12 x 12 backer. I also walked upfront in the bedroom area and there was the same sticker there My trailer does not have any TV mounts in it I am assuming may have to be put in and I am wondering is if I can screw them into that area
canible is offline   Reply With Quote
Old 02-23-2015, 02:05 PM   #643
Toby's Avatar
Those are to mark where the board is to screw into. You should be able to press on the wall with your hand and feel them there.
2018 Ford F250
Old 02-23-2015, 02:14 PM   #644
Tv mount
So is there a peice of wood 12x12 that i can screw a mount into. Any idea how thick it is. I want to put a full motion mount there if i can
Old 02-24-2015, 07:00 AM   #645
Toby's Avatar
Sorry I don't know. I would say 1/2 inch or somewhere in that area. That's what the one in my 25RR was. I have seen other folks mount their TV's in the corner and put support braces in the corners of the TV. I personally think the lag bolts that come with those mounts are too much for a swivel mount. Your best bet, if you insist would be to mount a piece of wood between two studs (which are like 2X2's) and screw into that. Sorry I couldn't be of more help.
2018 Ford F250
Old 02-24-2015, 06:49 PM   #646
Originally Posted by canible View Post
I just purchased a new to me 2010 19rr. I was looking things over the other day and where the TV goes it says there is a 12 x 12 backer Does that mean there is a 12 x 12 that I can screw A mount to. If there is what size screws do I need. Thanks advance Charlie
Hey, welcome to the forum...
I can get you some pics of my new 2015 19rr and you can see where the factory mounts by the bed.
hope this can help alittle.
2006 Honda Goldwing
2012 Toyota Tundra DC s(sold)
2015 Cherokee Grey wolf 19RR Limited
2017 F150 Super Crew 3.5eb 5.5
bluewoo is offline   Reply With Quote
Old 02-24-2015, 07:35 PM   #647
My bad - nothing mounted. I just have a tv mount I need to install myself.
sorry
2006 Honda Goldwing
Old 03-03-2015, 07:31 PM   #648
Wheel chock
Has any one used a bolt it on wheel chock in there 19 rr
Old 03-04-2015, 07:21 AM   #649
Toby's Avatar
Pass for me. I have seen others in this thread mount their chock to a board and lay that down. It seemed like a lot of work to me. You have to be careful what you screw into...it may just be a water tank. I bet if you scroll back (providing you have the time), you can see the examples that others have done. It's a long thread though but you'll get a lot.
2018 Ford F250
Old 03-04-2015, 08:50 AM   #650
retired06's Avatar
I bolted down my harbor freight chock in my 2015 19rr.
Don't worry about the mule, just load the Wagon!
2015 Grey Wolf 19RR (Wagon )
2014 F150 XLT ECO Boost max tow (mule)
retired06 is offline   Reply With Quote
Old 03-04-2015, 10:05 AM   #651
retired06's Avatar
What I did, was removed the tie down next to the refrigerator and poked a steel rod through the nylon webbing in the center of the hole next to the stud (for reference ). Then crawled under and there is about a foot of space between the clean and grey tanks, in front of the clean tank there's a metal support that the floor studs lay on, you can feel the studs and mark their center on the metal and measure their distance from the rod so that you can find them inside the trailer. I made a couple of anchors using 3/8 all thread, two hd fender washers and two long 3/8 hanger nuts. I screwed the all thread half way in the nut then screwed a 3/8x3/4 bolt with fender washer on the other end and wire welded the rod and washer to the nut. I had to weld two pieces of 2" square tube cut back on a 45' angle to the right side of the chock so that it would be bolted through two studs. I drilled through the metal support center through the stud all the way through the floor with a 3/8 drill bit, then from the top side, I used a 9/16 bit and drilled down the distance of the nut. When you tighten it down, you can barely feel any hump on the floor.
Old 03-15-2015, 06:58 AM   #652
Screww leingth
Does any one have any idea how long of a screw can i use. Safely for a tv mount in a 19 rr
Old 03-15-2015, 05:26 PM   #653
go to post #6
2006 Honda Goldwing
Old 04-07-2015, 05:08 PM   #654
wow your thread is awesome I am taking delivery on my 2015 19RR in a few weeks and all this information is going to help thanks.
Mistman
2015 Greywolf 19RR
2012 Victory Kingpin
2011 Ford F150
mistman is offline   Reply With Quote
Old 04-08-2015, 07:56 PM   #655
Did you read all 66 pages yet? Welcome to the forum!!
2006 Honda Goldwing
Old 04-22-2015, 07:06 PM   #656
Ok getting my toy hauler ready. I have a 2010 19rr. What is the best way to load a bike. I have a 07 ultra. I dont want to drag every time I load. I asked the lady i bought it from how they did it. She said her boy freind always did it but he has passed so she didnt know how. Any tips orvadvice would be appreaciated. Thanks in advance
It gets mighty lonesome in the saddle when the horse dies
2010 Grey Wolf 19rr
2010 Chevy Silverodo
2007 HD Ultra
Old 04-23-2015, 06:54 AM   #657
Canible most have just raised the front jack - i still need to load my bike too see if it will not drag also. Goodluck
2006 Honda Goldwing
Old 04-26-2015, 09:24 PM   #658
Raise the tongue as high as you can. Might want to raise the rear ramp 6" or so with chocks and use a ramp extension.
2012 Cherokee Grey Wolf 21RR
2012 Tundra Double Cab 5.7l
2010 Harley Ultraclassic
2015 Victory Gunner
Smithee is offline   Reply With Quote
Old 05-04-2015, 06:47 PM   #659
Ok I finally took my 19 rr out for the first time! Almost everything worked great except the black water flush connection was not tight enough causing it to leak on exit side of vac valve but I fixed that today. Had a blast, truck towed well and forgot to adjust brake boost on P2, dog cables, teeky torch oil, I think thats it.
8/9 mpg and dont care - anyone that does is just silly!
Oh the bed sucks ass and I got very little sleep so any cheap fixes?
I was a little heavy on the rear going up so I used another link on wdh and that did the trick with no more rear bounce.
ID:	76152   Click image for larger version
ID:	76153   Click image for larger version
ID:	76154   Click image for larger version
2006 Honda Goldwing
Old 05-04-2015, 06:58 PM   #660
Get a 2" memory foam mattress topper. Works great and very comfortable.
Memory Foam Mattress Topper
2015 Victory Gunner
19rr grey wolf
