Old 07-23-2013, 09:13 AM   #521
Question. We stayed at a campsite that had full hook up. My "stock" sewer line that came with camper wasn't long enough. So I want to buy an extension. Is there anything specific I should buy and is there a way to add another storage tube under the TH so I don't have to store this in my storage space?
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=2
Electra glide is offline   Reply With Quote
Old 07-23-2013, 09:21 AM   #522
The CG host laughed at my stock sewer line when he saw it.
I too would be interested in a high quality one with everything I need.
This is what I am considering now
Amazon.com: Camco 39861 RhinoEXTREME 15' RV Sewer Hose Kit: Automotive
2013 Rockwood Mini 2503S
2011 Chevrolet Silverado 1500 5.3L
Bryan2503S is offline   Reply With Quote
Old 07-23-2013, 11:50 AM   #523
Phat Phrog Phlunky
essness's Avatar
I went with the Rhino Flex hose. It's worth every penny when it comes time to dump
Keep in mind it will not fit in the hose holder you got with the trailer.
I made a new holder,
Forest River Forums - essness's Album: Mods
I have since bought a new trailer and it will not fit. So, if anyone is interested in the sewer hose assembly ready to bolt on to a 19, 21, 25 RR id sell it for the 25.00 I've got in it. But you would have to pick it up.
Scot, I am "that guy"
2014 Raptor 27FS
2014 Ram 1500 Laramie
Days camped in 2013 = 30 final.
Days camped in 2014 = 27 final.
igkra.com
essness is offline   Reply With Quote
Old 07-23-2013, 12:04 PM   #524
The thing is it will fit !!!! You just need to grind lugs down a little bit . And it will fit
Perfect . And still plenty of lug left to be able to twist to make connection .
Also I needed to trim hose about 3" to make the length fit also .
Sam2581 25rr 2014
sam2581 is offline   Reply With Quote
Old 07-24-2013, 04:24 AM   #525
heytomgraywolf's Avatar
Check out page 8 and 12 of this thread for sewer hose storage examples.
HeyTomGrayWolf
2012 Grey Wolf 19RR
2012 Toyota Tundra Crewmax 5.7l
2006 Road Star Warrior
heytomgraywolf is offline   Reply With Quote
Old 08-12-2013, 12:58 PM   #526
Toby's Avatar
Originally Posted by sam2581 View Post
My DVD wasn't working. Took cable connection down from ceiling and found when they put it together they broke tab off cable . Had to run new 6' cable now it's all better.
Sam2581
My antenna doesn't work worth a crap either. We just gave up on it. Maybe I'll tear mine apart sometime and see if I have the same issue. It only works if the park is broadcasting a repeater signal or if we are parked very close to the antenna. Otherwise it's like satellite tv in a heavy rain storm.
2018 Ford F250
2019 Arctic Wolf F295QSL8
Toby is offline   Reply With Quote
Old 08-12-2013, 06:58 PM   #527
Live 2 Ride Ride 2 Live
RKelly056's Avatar
Crappy Antenna
Have you activated the signal booster? It is a small pin button next to the cable to tv a light will come on. When the booster is not activated my antenna won't work either.
Rick Kelly
RKelly056 is offline   Reply With Quote
Old 08-12-2013, 07:13 PM   #528
Toby's Avatar
Booster
Yes I have played with that and it helps some but there are times when other campers have had a wonderful signal and we get nothing. Either that antenna is crap or something isn't tight up in there (which I never thought of until reading the forum here). If I'm hooked up to cable we have to turn the booster off or else the cable won't work at all.
2018 Ford F250
Old 08-12-2013, 08:20 PM   #529
Phat Phrog Phlunky
essness's Avatar
I would pull all the ends off and re do them. I had the same issue with my 21RR. I put new connectors on all the cable ends and it fixed the problem.
You are correct to turn it off for cable.
Belden - SNS1P6 - Coaxial/RF Connectors - RF Connectors - Allied Electronics
Coaxial Cable Compression Tool
2014 Raptor 27FS
igkra.com
Old 08-13-2013, 08:02 AM   #530
dstrauss2's Avatar
We just got home from the 2013 Goshen FROG Rally. We were having a problem with the antenna in our 21RR also. Antenna would work on a TV in the living area but not in the bed area or outside. A FR tech came and took the antenna box down over the TV in the living area and one wire was not attached at all and another was really loose. He hooked the wires up correctly and now the TV works well (and finds stations) in all three areas . He said when we are connected to cable TV in a campground to make sure the antenna booster button is OFF. Hope this helps!
dstrauss2 is offline   Reply With Quote
19rr grey wolf
