Old 05-11-2013, 07:49 PM   #481
heytomgraywolf's Avatar
That it was actually about making mods to a gray wolf toy hauler.
HeyTomGrayWolf
2012 Grey Wolf 19RR
2012 Toyota Tundra Crewmax 5.7l
2006 Road Star Warrior
heytomgraywolf is offline   Reply With Quote
Old 05-13-2013, 06:19 PM   #482
Live 2 Ride Ride 2 Live
RKelly056's Avatar
Originally Posted by heytomgraywolf View Post
Friday night, we put a towel rack in the bathroom. We found this one online from Kohls (Tip, if you have a Kohls near your, go into the store and order this on their Kiosk. If you order things from online at the store, you get free shipping to your home versus if you order online you pay shipping). This towel rack has two bars, front and rear and you can stack a few towels on top. I think I have seen these in some hotel bathrooms. Here is the link and a photo of what it looks like.
Chrome Bath Shelf and Towel Rack
Tom
Thanks for the idea we did the same thingClick image for larger version
Rick Kelly
RKelly056 is offline   Reply With Quote
Old 05-13-2013, 06:22 PM   #483
RKelly056's Avatar
Today I added a shelf in the bedroom. There is a nice outlet up by your head when laying in bed that would be good for charging cell phones, but there is no place to put your phone. I found some finished shelving material at Home Depot (it is not good Formica, just vinyl coated particle board that is made by Rubbermaid). It is in the window and flooring section of the Depot and it is really for building your own shelving and bookcases. I cut the board down to 5" wide because I did not want to hit it getting out of bed and I made the length 28" (There is room for about 36", but again, I did not want to be hitting the corner of the shelf getting in and out of bed).
Now Lucille and I have a place to lay our cell phones and charge them at night and Lucille also says her coffee cup will rest up there once I get up in the morning and fix the coffee and bring her coffee in bed!??! Sound like someone is awfully spoiled for camping!
Here is what it looks like.
Name:	Bed Shelf.jpg
Rick Kelly
Old 05-13-2013, 06:26 PM   #484
RKelly056's Avatar
This afternoon I tackled something else that was bothering me with the 19RR design. The cabinet over the sink. I didn't like how it opened "up" and since they did not put in a shock to hold it up when opened, every time you go to use this cabinet you have to have both hands free, one to hold the door up and the other to use to get or put away what ever is in this cabinet. I decided to move the hinges, handle and spring latch 90 degrees.
I also did a similar modification to the divider inside this cabinet as I did the one under the sink. They put a divider in this cabinet to block all the wiring for the controls behind the white board. Again, it seems they just have a bunch of these dividers all made up at 12" and they just slap them in at an angle so they can use one size for every location. I trimmed about an 1" off of this one so that I could get it flatter. I also took the terminal connectors (4 of them) for the power awning and bent them all 90 degrees from the back of the switch since this electric device seemed to be sticking out the most. Pushing all the wires flat, I was able to get this divider much "flatter" and closer to the end of the cabinet so I increased the cabinet space. I finished off the bottom of the cabinet with some rubberized shelf liner they have a Wal-Mart for $0.99 a roll (I think it is about 5' by 12").
I do have two holes in my cabinet door now, from where the handle was, but it is not that noticeable and as "CampingQueen" said, you can just cover them with stickers (she suggested butterflies, but it would be nice if someone finds decals of wood grain similar to the cabinet color). I may try a little wood filler and mix some stain and dab on the wood filler. The holes from the old hinge connection point are not noticeable once the door is shut. Now I can open this cabinet and not have it slam down shut on me. (however, it does swing out very wide, so if you bend down to get something, make sure you don't stand up under it an bonk your head). Here are two photo's of it open and closed.
Cabinet Open:
Cabinet Closed:
Tom
Heres how we did it
Name:	Cabinet Over Sink B.jpg
Rick Kelly
Old 05-13-2013, 06:48 PM   #485
RKelly056's Avatar
This morning's project was to work on a motorcycle wheel chock for my RoadStar Warrior. Like Stargazerandu, I don't want to attempt drilling through the floor for both aesthetics and concern with hitting the fresh or gray water tanks. While I really like the BoltItOn.com solution and how it uses the factory eyelets to mount the chock, the $300 price tag and the $60 shipping is just a little hard for me to swallow.
I had a 34" x 48" piece of 3/4" plywood that was painted and carpeted in my garage that was from my dad's old pickup truck that he had a topper on and used as a shelf in the back of his truck. With it being carpeted on one side, I figured it was perfect to put on the "floor side" of my plywood chock base. I put the 48" dimension between the closet next to the couch over to the kitchen cabinets. I then pushed the plywood until it rested in the corner between the closet and the bathroom wall. Since the fridge sticks out slightly, the 48" width will be too much and you will have to cut back 5-7/8" by 3 or 4" in. The carpeted piece I used already had a notch for the sidewall of the pickup that it was used in, so I cut a generous portion out to clear the fridge and removed the notch that was there.
I figure since the straps going down to the eyelets will be pulling the motorcycle forward and the wheel in the chock will be pressing forward, the edge of the fridge and the wall of the bathroom will keep the plywood from sliding forward and will spread the load out over a large area.
Next I cut 2 rectangular holes out for the eyelets to be accessed. These too when the straps are in them should help keep the carpeted plywood resting on the floor of the trailer from moving around.
I used the carpet remains from cutting off the section for the fridge and contact cemented carpet on all the edges of this plywood so that carpet would be resting against any of the cabinets and walls so they don't get marked up.
Now, once my wheel chock arrives, I will have to test load the bike to determine where I want to mount the chock onto this plywood base and then use carriage bolts from the underside (carpeted side) and make sure they are recesses (or covered with more carpet after installing) so that the heads of the bolts don't rub and tear up the floor.
Below are some pictures of the plywood base. More pictures to follow once my wheel chock comes in.
Here is the top side with it in the trailer. Note the base rests against the bathroom wall and edge where the fridge sticks out.
This is a picture of the bottom side showing the 3/4" plywood completely covered in carpeting (including edges) for resting on the floor of the trailer:
Liked your idea and am using it myself
Name:	Wheel Chock Base B.jpg
ID:	30373   Click image for larger version
Name:	Wheel Chock Base C.jpg
Rick Kelly
Old 05-13-2013, 06:51 PM   #486
RKelly056's Avatar
Liked your ideaThis is ours
Name:	Counter Top Over Stove.jpg
Rick Kelly
Old 05-13-2013, 06:59 PM   #487
RKelly056's Avatar
Originally Posted by Stargazerandu View Post
Okay, here are my mods... And thank you all for all the tips! I don't think I could have done it without them....
I am not finished with the mods but this is what I've done so far...
Liked the idea about better support for the drawers Here is ours
Name:	Drawers Reinforcements A.jpg
ID:	30377   Click image for larger version
Name:	Drawer Reinforcements B.jpg
ID:	30378   Click image for larger version
Name:	Drawer Reinforcements C.jpg
Rick Kelly
Old 05-13-2013, 07:00 PM   #488
Very nice! Much nicer shelf by bed and you mounted it a little lower since we can't stand a water bottle up on ours. I so think the latch to hold up the cabinet door over the sink is good since what I did really makes it swing out wide. I have to duck! LOL.
HeyTomGrayWolf
2012 Grey Wolf 19RR
Old 05-13-2013, 07:04 PM   #489
Oh be careful holding up too much weight with the straps for the couch. The eyelet by the cabinets (front) is only screwed into the molding on mine and strapping our bicycles to the couch pulled mine loose.
HeyTomGrayWolf
2012 Grey Wolf 19RR
Old 05-13-2013, 07:13 PM   #490
RKelly056's Avatar
Different Straps and Locations
Oh I used a different strap and bolted it to a different location on the wall. It is very sturdy.
Rick Kelly
Old 05-13-2013, 07:19 PM   #491
RKelly056's Avatar
All My Mods To Date.
Gonna try and download an many pics as I can in the next few posts. Thanks to all of you for your great Ideas.
Awning Protector Cover ....
Name:	Awning Protector A.jpg
ID:	30380   Click image for larger version
Name:	Awning Protector E.jpg
ID:	30381   Click image for larger version
Name:	Awning Protector C.jpg
Rick Kelly
Old 05-13-2013, 07:25 PM   #492
RKelly056's Avatar
More
More of your ideas I used
Battery Shut Off Switch
Name:	Battery Kill Switch A.jpg
ID:	30384   Click image for larger version
Name:	Battery Kill Switch Cover.jpg
ID:	30385   Click image for larger version
Name:	Battery Tray A.jpg
Rick Kelly
Old 05-13-2013, 07:30 PM   #493
RKelly056's Avatar
still more
This is the battery tray and shelf I installed to go with my bigger battery box and swithc.
Name:	Battery Tray B.jpg
ID:	30387   Click image for larger version
Name:	Battery Tray C.jpg
ID:	30388   Click image for larger version
Name:	Battery Tray D.jpg
Rick Kelly
Old 05-13-2013, 07:34 PM   #494
RKelly056's Avatar
More more
This is a door panel and also a support prop for the bed board storage, also a shelf on the wall
Name:	Bed Base Lift Holder.jpg
ID:	30390   Click image for larger version
Name:	Bed Shelf.jpg
Rick Kelly
Old 05-13-2013, 07:42 PM   #495
RKelly056's Avatar
Hmmm
Name:	Black Trim A.jpg
Name:	Black Trim B.jpg
Rick Kelly
Old 05-13-2013, 07:57 PM   #496
recon33alpha's Avatar
Originally Posted by RKelly056 View Post
What did u do there?
2010 GMC SIERRA
2012 GREY WOLF 25RR
2012 campouts: 42
2013 campouts:1
recon33alpha is offline   Reply With Quote
Old 05-13-2013, 08:00 PM   #497
RKelly056's Avatar
aa
Name:	Wall Coat Hanger.jpg
Name:	Cabinet Over Sink A.jpg
Name:	Furnace Screen.jpg
Name:	Indoor Outdoor Temp.jpg
Rick Kelly
Old 05-13-2013, 08:11 PM   #498
RKelly056's Avatar
bb
Name:	Harness Holder A.jpg
Name:	Harness Holder B.jpg
Name:	Ramp  Table.jpg
Name:	Roof Vent Cover A.jpg
Name:	Roof Vent Cover B.jpg
Name:	Shelving Added.jpg
Rick Kelly
Old 05-13-2013, 08:24 PM   #499
RKelly056's Avatar
cc
Name:	Solar Charger.jpg
Name:	Spare Tire Carrier.JPG
Name:	TV Mount A.jpg
Name:	TV Mount B.jpg
Name:	TV Mount C.jpg
Name:	Under Bed Door.jpg
Name:	Wheel Caps A.jpg
Name:	Wheel Caps B.jpg
Name:	Wheel Covers.jpg
Rick Kelly
Old 05-13-2013, 08:27 PM   #500
Where did u get the hub caps, love those, easy eye pleaser
2010 GMC SIERRA
2012 GREY WOLF 25RR
2012 campouts: 42
2013 campouts:1
19rr grey wolf
