06-23-2017, 06:13 PM
#321
RiderBloke
Pimp my 26rr
Originally Posted by extxn
OMG RiderBloke!! The backyard is one thing with a new pond, but raising trout in the basement is not a good ideal. Hope you don't sustain too much damage down there and able to get it cleaned up quickly!
Currently pouring here (again!!), has been off & on for the past week or so, but at least we're on a hill top.
Wishing you lots of luck with this mess.
Thanks. All we lost was stuff we were going to get rid of. Four of the men from the Church - our house is a parsonage - removed any carpet, took off the baseboards and cut off the bottom 12 inches of drywall and will return to cut the wallboard tomorrow.
Our photos floated in a plastic box dry!
Meanwhile the 26RR was as dry as a bone and no basement flooding there! [emoji16]
Retired Intentional Interim Minister
Saginaw Valley BMW Riders
BMW Riders of Tampa Bay
Habitat Care-a-Vanner
06-27-2017, 09:50 PM
#322
No more siphoning from fresh water tank.
Added a connector and another length of tube and a valve. I now have full tank when I arrive at campsite after filling.
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2020 Ram 2500 Crew cab 6.5 bed
Ron & Shirley (Empty Nesters)
07-27-2017, 06:27 PM
#323
No functionality, but added theses items today:
Indoor/outdoor thermometer
Camping picture
2016 26RR and a 2018 OR371MBH
07-27-2017, 07:07 PM
#324
Were did you stick the receiver outside?
2005 Honda VTX 1300
07-27-2017, 08:51 PM
#325
On the inside of the awning post. Secured with Command Strips.
07-27-2017, 09:47 PM
#326
RiderBloke
I hang mine under the rear of the steps using a Velcro strap and hopefully remember to put it inside before I drive off.
07-28-2017, 06:36 PM
#327
See I'm to lazy and would want it permanent.
2005 Honda VTX 1300
07-28-2017, 10:56 PM
#328
It has a hole in the top where you could make it permanent. I considered on the tail side of the TV antenna. Out of the wind while traveling and not affected by direct sunlight. Maybe another day when I get more motivated.....
07-30-2017, 09:37 AM
#329
Pimp my 26rr
2005 Honda VTX 1300
07-30-2017, 09:41 AM
#330
Here is my generator hooked up to my propane quick disconnect.
2005 Honda VTX 1300
#331
Sorry here is the pic
2005 Honda VTX 1300
08-12-2017, 02:19 PM
#333
RiderBloke
The fridge/freezer looks interesting (esp if I end up with an ambulance TV).
What tires did you get?
08-12-2017, 03:02 PM
#334
They are a china brand (can't find many Merican 14" tires) called Zeemax. They have an additional 60# capacity per tire and they run at 65PSI.
08-12-2017, 09:19 PM
#335
Originally Posted by mxdad
Where did you put fridge? TV or in TT?
2005 Honda VTX 1300
08-12-2017, 09:23 PM
#336
Pimp my 26rr
My trailer has about 140# of new steel under it now. Lipert had to do that to straighten out my frame.
The camber was found to be negative when the techs checked my TT at Goshen.
Come to find out this is why I had a bow in the metal up high on trailer.
And I just took it through the scales again two weeks ago.
So my camper probably is heavier than MaxDads now!!!!
2005 Honda VTX 1300
08-13-2017, 09:44 AM
#337
It will normally sit outside, but since it has been raining, we put it under the table at the back. Don't even notice it back there.
Where did the techs reinforce your frame? Did they say if yours was a one time thing, or could it be something that affects others?
08-13-2017, 02:25 PM
#338
It reaches from about middle of trailer to almost the rear. I'll try and get pics. I had some bowing of the side panels and door issues they did a line test and it was negative camber. Frame suppose to be smile shape. Mine was part of frown in back.
2005 Honda VTX 1300
08-13-2017, 06:07 PM
#339
Ron, what year is your 26RR?
Did the techs have any clue as to what may have caused the situation?
Did you notice this with the tt just 'setting on the tires' or was it even evident when set-up on the leveling jacks?
08-13-2017, 06:09 PM
#340
BTW ~ how did your new to you tv handle the road & tug the tt along?
