10-07-2015, 04:37 PM
#21
those stands i bought on amazon ,they are actually step stabilizers for rvs . they r rated for 1000 pds each , and the ramp i bought at home depot,it was a single ramp , i just disassembled it and bolted it side by side to r make it wider.I strap the ramp to the back d rings which makes this very stable
10-08-2015, 08:37 AM
#22
Retired Techie
26 RR shake down
At Little River for a 3 day shake down. So far every thing works except TV wiring. Radio only works when antenna amp is on. Both cable and air is weak in bedroom. I wonder if I can get to the splitters through the ceiling or have to pull rock wall behind TV.
10-08-2015, 11:10 AM
#23
I just got my 2016 26rr a couple weeks ago, love it! Going to do a bunch of mods, will start a new post when I get started full force, already did a couple things. First thing I did was change the bathroom door, swings to the left now. Hated how it was always in front of the tv! Bad idea... Especially during football season... The knob is in the middle of the door so all I did was remove it, flip it over and screwed it in. I had to fill in the old latch hole with wood filler, and just used a black sharpie to darken it. And, the middle hinge goes over it so you can barely see it now. Then drilled a new latch hole on the other side, screwed in the plate and done.
Steve
Golden CO
2016 Grey Wolf 26RR Limited
92 GMC K2500 454
2006 Honda Rubicon ATV
10-08-2015, 12:07 PM
#24
Pimp my 26rr
They had my hook up wrong in behind the receiver. I pulled the font off took out screws holing it in and changed connections in the back. Now TV and dvd works both in living room and outdoors. I was hearing sound in speakers but no picture.
Your antenna only works when amp on. Unlike my old camper which had a radio antenna an separate TV antenna I think this camper both are built into one. The only time you would not use booster is if you were hooked up to land cable.
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2020 Ram 2500 Crew cab 6.5 bed
Ron & Shirley (Empty Nesters)
10-08-2015, 02:33 PM
#25
Retired Techie
There is a white and black coax connected to radio. I assume one is from amp and one from TV antenna. Connections Must be behind tv and I don't want to pull wall while on road.
2005 Wolf Pack WP22
2016 Grey Wolf 26RR-Traded in
2004 Siverado 2500HD Duramax Sold w225,000
2013 Keystone Springdale 5r Sold
1998 Honda Valkerie Sld
2016 Camping 148 days so far Bought park model and moved to Florida.
10-08-2015, 08:03 PM
#26
My outside connection did not come into the Sat connection on the inside plate, it was connected to the booster which caused a fuzzy picture with the booster on or off. I pulled a second cable to the front room from the entertainment center and installed a couple of splitters and duplex outlet. My outside connection now comes to the entertainment center and front room uninterrupted, I hook up campground cable or set up a high quality HD antenna. Simple change to the other connections allows use of the factory antenna, which is less than stellar. Test of the provided antenna versus my outside antenna, 6HD channels versus 101 sitting at the same campground.
2015 26RR
2013 F150 5.0
2011 Harley Touring
10-10-2015, 03:24 PM
#27
Retired Techie
26RR shake down
Well 3 days at Little River and most every thing worked well.
Unit towed easy compared to my equal weight but tall WP22.
Loved the 10" foam mattress. May get one for the house.
Antenna distribution is screwed up. I think it is just wired wrong but I believe I will have to add a (In door) FM antenna. I don't think the radio will like the voltage on the wire going to the tv antenna when the amp is on. Maybe I can locate it behind the tv wall. If not radio won't work depending if amp is on or not.
Low 40's and upper 30's each night. Unit heated easy. Floor was a little cold towards front. Used a Infared Quartz heater mid ships to supplement propane heater. Really didn't need it as bedroom stayed warmer with the propane heater but I am cheap. (park electricity vs my propane). Three days and didn't use a 20# tank for heat and water.
One very important thing and I think I heard this before. Use the dead bolt to lock the door. Got home and the locked door with upper latch was open. Apparently unit flexes enough to allow door to open.
Next trip Dec 1 - May 30we head for Ho-Hum RV park and shrimp heaven then south as the weather cools..
2005 Wolf Pack WP22
10-10-2015, 03:44 PM
#28
RiderBloke
Glad the trip went well. I found the floor in the living area was pretty cold on cool mornings. We have put carpet down in just about the whole living area - 2 pieces. I like carpet under my feet. I roll the larger one up when the bike is in and move the other one under one seat - it's a runner sized carpet that goes between the seats.
My radio & TV wiring and reception have been correct so I hope you can fix yours.
I'm in Michigan also and will head south mid November.
Presently building 4 boxes to hold the tools I need for NOMADS & Habitat. They go under the seat on the left which stays down when the bike is in. The table saw is in the front of the bed of the truck along with the trailer's spare tyre.
Hope I've got the weight distribution about right with all I've added since I had it weighed. Towed OK with bike in. The tools shouldn't add that much weight. [emoji16]
Sent from my iPhone somewhere on the face of the earth using Tapatalk
Retired Intentional Interim Minister
Saginaw Valley BMW Riders
BMW Riders of Tampa Bay
Habitat Care-a-Vanner
10-15-2015, 04:54 PM
#29
like the idea for the couches , almost done that renovation. I also relocated the fire extiguisher
10-15-2015, 05:02 PM
#30
I like the idea of re-configuring the couches. Has anyone tried to move them back so they are closer to the ramp? Seems like it would open up the living area a bit, and give you some wall space next to the sink counter. And, with the couches setup like this the back rest will be up against the ramp.
Steve
Golden CO
92 GMC K2500 454
10-16-2015, 08:02 AM
#31
Pimp my 26rr
I'm actually going to make a removable back for the couch so when it's nice weather I can have ramp down and screens down and be able t lean back without falling out the back. I will upload pics when I get it done. I plan to do that this weekend.
Just for more details when I did the couch mod I unscrewed the two 2x6s from wall and cut to width of couch. This made it so you don't have boards sticking out on wall makes cleaner look. I also put heavier hinges on since the old ones were bending. Also put a support board under for more support.
2005 Honda VTX 1300
10-16-2015, 03:39 PM
#32
yea i did that too, that was just the excess of the cover before we wrapped and cut the excess off. i am interested in how you plan on adding a back for the summer.i thought a padded angled piece acrossmthe door opening but that seems kinda bulky
10-17-2015, 09:13 AM
#33
Retired Techie
Decided to use space between couches and ramp door for storage instead of moving. Tie downs, broom etc. Perfect space for infared heater between left couch and fender well.
Reconfigured straps on both sides to hold back above couch and added strap on bottom of left couch to hold chairs, table etc. Also built 8" x 8" x 5' drawer for under left couch for jacks, wrenches etc.
Probably will leave left couch up all the time but after living in all winter will have a better idea what works.
I am adding a ramp to the gate today. I put a 1/2 " plywood ramp on 4' by 18" with a piano hinge which was to weak and to short so am working on Rev 2. 3/4 " plywood 24" wide by 4' with two hinges to allow a droop of 4-6" on the extension. Then have to find two 6 " rubber bumpers for the outside of door to replace the short ones.
Just sold my winter tires and put on road tires so I guess I am committed to warm country for the winter.
2005 Wolf Pack WP22
10-18-2015, 05:48 PM
#34
Pimp my 26rr
Here is my solution to the back of the couch.
1 1/2 inch pvc pipe, 90 degree elbows, plug, and caps.
2005 Honda VTX 1300
10-18-2015, 05:50 PM
#35
Plugs screwed onto benches and elbows pvc glued on to plug. The uprights are removable.
2005 Honda VTX 1300
11-06-2015, 07:30 PM
#36
Radio amp?
When you guys mention the radio amp, what are referring to. I know what an amp is but I do not see one or a button for one. I have a 2016 26RR.
Thanks - Patrick
11-07-2015, 02:03 PM
#37
Does the pvc give enough support? I would think it would flex too much when you leaned back
11-07-2015, 06:36 PM
#38
RiderBloke
Thanks - Patrick
Patrick,
If you look at the 12v outlet in the ceiling near the Entertainment cupboard, you will find a very small push button on that plate. It is very small. Press it upwards and a green led should come on. That's the amp for the TV signal etc. why it is so small and so obscure is known only to some designer who never used it in real life. If it's not on you get nothing.
Hope that is what you needed to help out.
Ron.
Sent from somewhere on the face of the earth with my iPad/iPhone using Forest River Forums
2014 Toyota Tundra towing 2016 Grey Wolf 26RR
29 nights camping & 1926 miles towing so far
11-07-2015, 09:34 PM
#39
Yes it does. I'm 220lbs and does well. It has worked well. I used pic over wood for weight. Very minimal flex.
2005 Honda VTX 1300
11-07-2015, 09:38 PM
#40
Pimp my 26rr
Makes it really nice. The screws and pvc glue on the elbows and caps make it very sturdy. The uprights when pushed in don't move.
2005 Honda VTX 1300
