Originally Posted by mikegernes
Hello,can anyone help me. I have a 2017 26RR. The bedroom lights do not power. The bathroom fan does not power. And the heat and ac on the wall do not power. The bedroom 15 amp fuse is blown, if you replace it blows again, what direction do I go.
Sounds like you may have a wire that is either exposed or has a nail in it or a grounding issue
I had a van once that kept blowing circuit when I turned on the lights. Found out that someone stuffed the 4 pin trailer connector into the receiver hitch to keep it from hanging down. The exposed pin was up against the metal and grounding out the lights and blow the fuse. I would check your grounding wire bus in your bos to make sure your wires are secure and one is not outloose. Good luck.
