Old 12-05-2015, 09:04 AM   #61
RiderBloke
RiderBloke's Avatar
ChipBruce
It's wasted space. Rmac04401 has it right. I use it as pantry. It can all be restored if needed when I sell.
Sent from my iPhone somewhere on the face of the earth using Tapatalk
Retired Intentional Interim Minister
Member of the BMW MOA
Saginaw Valley BMW Riders
RiderBloke is offline   Reply With Quote
Old 12-05-2015, 09:34 AM   #62
Pimp my 26rr
You can pull the fake rock wall off and see for yourself. There are 4 screws holding the rock wall and you will have to remove the tv mount. There is a board behind the tv mount for support, you will see what i mean when you get it pulled off. After you take it off you will be able to put it back on just as easily. I will take some pics and post them today to show what i did. And i thought this was a waste of space too, not sure why someone would think that was a good idea.
Steve
Golden CO
2016 Grey Wolf 26RR Limited
92 GMC K2500 454
2006 Honda Rubicon ATV
zuterbru is offline   Reply With Quote
Old 12-05-2015, 09:39 AM   #63
RiderBloke
RiderBloke's Avatar
I have a theory. Forum writers complained a lot about how small the TV was that fitted onto the rear wall of that space. False front gives a bit more TV width. Just my speculation.
Old 01-06-2016, 05:02 PM   #64
vintage's Avatar
Originally Posted by statticcling View Post
man love that idea for the couches , we didnt like that original layout either. i added the cabinet on the wheel well. added a lock to the bedroom door, put gas struts on all overhead cabinets . made a false floor for passenger bedroom cabinet.Next up is shelfs in the entertainment area and a pantry next to the wheel well cabinet
Hi Statticcling...what length gas struts did you use for the upper cabinet doors? Thanks Vern
2016 Grey Wolf 26RR
2011 Can am Spyder RTS
2015 Arctic Cat TRV 1000XT
2016 Dodge Ram 1500 Crew Cab 4x4
vintage is offline   Reply With Quote
Old 01-06-2016, 05:42 PM   #65
I added them myself, 10", these are what I installed: Durable Hydraulic Gas Strut Lift Support Kitchen Door Cabinet Hinge Spring Brass | eBay
Others said they used the 50NM but they where not available, I think I had to go with the 80nm but they work fine. This is basically the amount of force they push out, so mine have more power! The instructions did not work for me, I had to mount them different. I think I had to have the top mounted higher, otherwise they would not close. Mess with one, get it to work then measure for the rest of them, piece of cake after the first one. MAKE SURE YOU DRILL PILOT HOLES! I was actually impressed, the wood is pretty hard, broke a screw or 2 screwing it in. Pretty simple mod but a must have for sure!
Steve
Golden CO
92 GMC K2500 454
Old 01-09-2016, 11:21 AM   #66
i used apexstone 100n/22.5lbs they r 10.6 inches .12.99 on amazon for 2 .,they work well and i added them to all the doors. i am going to try them on the bed to see if they would hold that up as well .i think i had to reverse the mounting tabs from the way the directions said to mount it.
statticcling is offline   Reply With Quote
Old 01-12-2016, 06:55 PM   #67
Thats awesome, just bought a 25RR and was wondering about that space, problem solved!!
Dave, Deb and Cosmo the Wonder Dog
donkey is offline   Reply With Quote
Old 04-10-2016, 12:15 PM   #68
rmac04401's Avatar
Just installed a Maxxiair fanmate fan cover simple mod. Installed my own bug screen to keep bugs out. Click image for larger version
Name:	ImageUploadedByForest River Forums1460308414.591046.jpg
ID:	104477Click image for larger version
Name:	ImageUploadedByForest River Forums1460308425.440585.jpg
ID:	104478Click image for larger version
Name:	ImageUploadedByForest River Forums1460308438.391789.jpg
ID:	104479Click image for larger version
Name:	ImageUploadedByForest River Forums1460308454.974195.jpg
ID:	104480Click image for larger version
Name:	ImageUploadedByForest River Forums1460308467.375415.jpg
ID:	104481Click image for larger version
Name:	ImageUploadedByForest River Forums1460308479.657286.jpg
Very easy install and gives most space to open the fan top.
2016 Grey Wolf 26rr
2005 Honda VTX 1300
2002 F150 5.4L extended cab 6.5 bed
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 04-13-2016, 09:22 PM   #69
rmac04401's Avatar
Pimp my 26rr
Fixed leak in black water tank flush. Thought it was coming from the cheap plastic vacuum break. Replaced with metal one. Found out the black plastic clamp they had on hose was not tight. Click image for larger version
Name:	ImageUploadedByForest River Forums1460600491.289374.jpg
ID:	104838Click image for larger version
Name:	ImageUploadedByForest River Forums1460600514.239202.jpg
2016 Grey Wolf 26rr
2005 Honda VTX 1300
Old 04-26-2016, 08:26 PM   #70
rmac04401's Avatar
Pimp my 26rr
Added another LED light by the front door where it was dark. Looks like it came this way. Got light off amazon same manufacture and model number as rest. Attached to the other lights in the circuit with the switch. Eventually will be putting in a dimmer on that circuit.
Name:	ImageUploadedByForest River Forums1461720172.151571.jpg
Before
Name:	ImageUploadedByForest River Forums1461720201.918256.jpg
After
Name:	ImageUploadedByForest River Forums1461720229.783995.jpg
Name:	ImageUploadedByForest River Forums1461720244.386786.jpg
In between
Name:	ImageUploadedByForest River Forums1461720270.334283.jpg
So called insulation in ceiling. At least not as bad as vermiculite insulation that was in my 1920's first house.
Name:	ImageUploadedByForest River Forums1461720348.933670.jpg
Panned shot.
Now I can actually read what switches say on them at night.
2016 Grey Wolf 26rr
2005 Honda VTX 1300
