are you asking if you can connect the shore power cord to the generator without a battery installed? short answer, yes.
i'm assuming that you expect the converter to supply 12 volt power in order to run the lights. it should be able to do this but you will not have a robust 12 volt power system like you would if a battery was installed. the battery can supply bursts of power to operate 12 volts devices that need a burst (slides). the converter cannot. i don't see an issue for a short period of time.
why is there no battery installed? i'm guessing you took it out while in storage so that it will not get discharged. it you install a true battery disconnect and have the batteries fully charged before you put it in storage they will last several months without a discharge.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
