Old 05-22-2017, 10:13 PM   #1
Question about the LP line on my 26RR
I noticed that the propane line coming from my tanks is mounted UNDER the frame, instead of going through a perfectly good hole in the frame, right beside the bracket. Is this right?
Seems very sketchy to me! The first thing to drag is the propane freakin line? I mean, I drive with the propane tanks on, so that the fridge works.
Are all 26RRs like this, or were they just being lazy?
Gary44 is offline   Reply With Quote
Old 05-23-2017, 08:45 AM   #2
SeaDog's Avatar
I wouldn't like that and would reroute it. Maybe other Cherokee owners can check theirs and let you know. On my rig its up alongside the frame
Retired Navy
2016 Flagstaff 26 FKWS
Old 05-23-2017, 09:18 AM   #3
Phat Phrog Stunt Crew
elind's Avatar
Will the long straight piece of iron pipe slide all the way thru the frame without bending it to get it in?
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 05-23-2017, 01:07 PM   #4
What year is yours? I will have to check mine out, dont remember seeing that.
Steve
Golden CO
2016 Grey Wolf 26RR Limited
92 GMC K2500 454
2006 Honda Rubicon ATV
zuterbru is offline   Reply With Quote
Old 05-23-2017, 05:57 PM   #5
Mine is 2016 and this is mine. Either like you said they were lazy or they could not get straight line to your quick connect. Click image for larger version
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2020 Ram 2500 Crew cab 6.5 bed
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 05-23-2017, 06:01 PM   #6
Lipeart could have put hole in wrong place and pieces did not line up and instead of drilling new hole they just tagged on bottom.
Should not be an issue. If you drag up that high you will have serious issues
2005 Honda VTX 1300
Old 05-23-2017, 06:57 PM   #7
Thanks for the responses. Mine is a 2017.
Probably wont be an issue, but I guess it's just the principle. I hate stuff that's done half assed. I'm gonna add it to the list of warranty repairs.
Sent from my SAMSUNG-SM-G900A using Forest River Forums mobile app
Old 05-23-2017, 11:04 PM   #8
Mine is the same also. My Jayco Jayflight is also routed under the frame as was aFranklin tt I had also. I believe it is the industry standard.
Aggitator is offline   Reply With Quote
Old 05-24-2017, 01:49 PM   #9
My 27RR is the same way. It has bugged me since day one, but as others have said it shouldn't be an issue. I do agree though, it could have been routed MUCH better.
joshgarza219 is offline   Reply With Quote
