Old 11-20-2017, 11:37 AM   #1
Refrigerator too cold
Our refrigerator is so cold it is actually freezing some of our food. Any ideas on how to regulate temp ? There is no temp dial like there would be in a conventional frig.
ruddie66 is offline   Reply With Quote
Old 11-20-2017, 11:43 AM   #2
Pickin' & Campin'
Please post the make and model # of the refrigerator.
Always post as much information as possible, such as, including make/model, R/V type or residential refrigerator, whether this is an on-going problem or just started happening and what you have done to try and rectify the issue.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
2017 Ford F-Series SCREW 4x4
Days Camped: '15=22 '16=46 '17=30
Old 11-20-2017, 11:44 AM   #3
Berkshire 390QS
NO3putt's Avatar
What kind of refrigerator? Skip
2015: 188 days, 2016: 72 days, 2017: 185
Skip
Old 11-20-2017, 11:50 AM   #4
Berkshire 390QS
NO3putt's Avatar
If it's a domestic, there should be a white thermister attached to the fins that should slide up and down that will adjust the temperature. If I remember correctly, slide down for cooler, up for warmer. Skip
Skip
Old 11-20-2017, 02:13 PM   #5
Itís a Norcold,thermister is not quite all the way up, so I just slid up as far as I could so to not be off the fin. See what that does. Thanks all for your input.
Old 11-24-2017, 10:18 AM   #6
With the thermister moved up, refrigerator is running normal. Thanks.
refrigerator
