Old 07-02-2015, 09:45 PM   #1
Roof air vengence 376V
Last camp out my fan ran continuously even when temp was reached and compressor turned off. ( like the old ones do) If I'm not mistaken it works same as home ac unit and fan turns off. If so what's wrong. Only been used handfull of times. 2014 yr model. Thermostat?
Kickingupmudd is offline   Reply With Quote
Old 07-03-2015, 12:09 AM   #2
iceblaze580's Avatar
Switch the fan setting to auto that should fix it
iceblaze580 is offline   Reply With Quote
Old 07-03-2015, 06:59 AM   #3
It is on auto. I think I will try it on heat and see if it turns off.
Old 07-03-2015, 06:34 PM   #4
You may want to try turning off the breaker to see if it resets itself
Old 07-04-2015, 03:48 PM   #5
You were right it wasn't on auto. Didn't even know it had lo Hi auto on fan setting. Thanks
Old 07-04-2015, 11:10 PM   #6
Glad I could help
roo, roof
