Old 05-31-2012, 01:42 PM   #11
Comfun,your profile says you have a 1986 Motorhome,what year is your TT? If your TT is older ,and in the sun,the wire going to the Batt. could be orange. Youroo!!
Old 05-31-2012, 02:01 PM   #12
My TT is 2012 21rr Grey Wolf and I found the fuse. It was right under my nose. I pulled it out and the terminals are covered in white powder which I am guessing is corrosion. Would dielectric grease be a good idea for this?
comfun1 is offline   Reply With Quote
Old 05-31-2012, 05:42 PM   #13
caper's Avatar
Dialectic grease will help. If you want you could wire a battery disconnect on the wire coming from the jack. You would then only have to switch off the disconnect. The pail over the top works great. It keeps the water off the jack. I have put a clamp on the inside that I attach the 7 way plug to. It keeps the plug off the ground and prevents water from getting into the plug. I clip my safety chains to the handle of the pail to hold it in place.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 05-31-2012, 05:47 PM   #14
rbq
I'd put a battery cut off switch on the battery box. Connect the ground wire through the switch. Switch off--no connection & nothing works.
rbq is offline   Reply With Quote
Old 06-01-2012, 07:21 AM   #15
KyDan's Avatar
Nothing works-- includes the refrigerator!
Everyone should have a battery cutoff switch but in this thread we're talking
about disabling a power tongue jack.
Good that he found the fuse!
I -hate- hidden fuses! At least this one has been located
Old 06-01-2012, 07:25 AM   #16
caper's Avatar
He could add a battery cut off switch to the jack. It would cut off the power going to the jack but allow everything else to work off the battery.
Terry and Janet
2007 Ford F150
Old 06-01-2012, 08:39 PM   #17
Sockman's Avatar
I agree with most - just remove the inline fuse. That ain't exactly fool-proof, though, if someone really wants to lower your tongue, they'll put another fuse in it. Like others said, you can't protect from everything.
2011 Wolf Pack 19DFWP
Sockman is offline   Reply With Quote
