Old 08-20-2014, 10:21 AM   #1
Surround sound receiver for the TH
Looking for a surround sound receiver for my Wolfpack 30 WP. This will be hooked up to the TV. Already has speakers installed. Any suggestions ?
Lead, follow, or get outta the way !!
3fan4evr is offline   Reply With Quote
Old 08-20-2014, 10:53 AM   #2
Kaadk's Avatar
What kind of surround sound are you talking about? Like a 7.1 system or a basic L/R & F/R? Also, are you looking at a home theater system running on 110v or car audio system running on 12v?
There's no use crying over spilt milk, unless it's on your keyboard.
Old 08-20-2014, 02:58 PM   #3
5.1...HT on 110v
Old 08-20-2014, 11:09 PM   #4
camaraderie's Avatar
Do you have speakers you are planning to hook up to? Passive or Powered Subwoofer? Start with those...then figure out your needs in a receiver. Also...what are you planning to hook up to the receiver. How many HDMI's do you need...blue tooth...etc. You need to figure this stuff out before recommendations can be meaningful.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 08-21-2014, 03:43 AM   #5
As stated, speakers are already in place. As stated, a TV will be hooked up to the receiver.
Old 08-21-2014, 10:08 AM   #6
The already installed speakers are 4 ohm car speakers and are incapable of handling real power and may blow the output transistors of home 120V receivers designed to power 8 ohm loads (though some more expensive home receivers are capable of 8 ohm loads). 5.1 receivers are virtually out of production today in favor of 7.1 models. For a greater selection of features and price...suggest you look at 7.1 and just wire up 5.1 if you don't want sides and rear effects.
I would further suggest that you understand that a 5.1 set up will ONLY give you effects from the second pair of speakers so you may wish to consider if you want full sound spectrum only up front ...or if a receiver with the ability to power a pair of "B" speakers for another room is needed.
I strongly suggest replacing the car speakers ... both for compatibility as discussed above AND because $3 speakers suck. If you don't...buy a cheap receiver as you won't notice any difference anyway.
I understand a TV will get hooked up. So this means a blue ray player will not be hooked up. A video game will not be hooked up. An Ipod will not be hooked up, a usb stick will not be hooked up a radio will not be hooked up and the surround sound digital audio from a satellite dish will not be hooked up. Right? Exactly WHAT from the TV will be hooked up? HDMI output, Composite audio and video, component video/audio, digital optical audio out, coaxial digital audio out?
________
Cam
Old 08-21-2014, 12:28 PM   #7
Thank you for the advice. Greaty appreciated
