Old 08-11-2012, 11:59 AM   #1
Phat Phrog Phlunky
essness's Avatar
Tire wear on 21RR/19RR
I just happend to notice yesterday when I was putting my c-chocks on that the inside of my tires on both sides and all 4 are wearing tremendously on the inside?
I'm always dilligent about checking pressures and keep them at about 45lbs. They appear to crown and I would expect them to wear in the middle of the tire based on appearance....... Anyone have any expirience with this?
It's a 2012 and we have only put about 6000 miles on the trailer. I find it difficult to believe this is standard tire wear?
Scot, I am "that guy"
2014 Raptor 27FS
2014 Ram 1500 Laramie
Days camped in 2013 = 30 final.
Days camped in 2014 = 27 final.
igkra.com
essness is offline   Reply With Quote
Old 08-11-2012, 12:53 PM   #2
If all 4 tires are wearing on the inside, there are only 3 causes possible: 1) Wheel brgs are loose 2) both axles are bent or do not have the proper camber in them 3) grossly overloaded
It is definitely a dealer repair issue. Take it back to the dealer.
Old 09-05-2012, 04:39 PM   #3
my 19rr as less the 5000 miles and i have to replace one of the tires which as the inner belts blown, all 3 other tires are showing uneven wear and are already half worn...
I will be replacing with Goodyrear tires, originals are cheap chinese junk!!
these cheap tires should not even be legal
braz28 is offline   Reply With Quote
Old 09-05-2012, 05:27 PM   #4
Goodyear marathons are also chinese junk. So all you will gain is the name.
Old 09-05-2012, 05:32 PM   #5
QUOTE=donn;247967]Goodyear marathons are also chinese junk. So all you will gain is the name.[/QUOTE]
Let's not open that can of worms again donn.
Old 09-06-2012, 04:33 PM   #6
Not a can of worms except in your mind. Simply stating facts. Maxxis seems to be the best option in an ST tire. But I would certainaly have axle alignment checked by a qualified shop before I spent money on tires. Could simply be cheap Chinese junk with belt failures.
Old 09-06-2012, 07:01 PM   #7
Herk7769's Avatar
Don,
You have beat this horse many times in the past.
There are many of us who are quite happy with our Marathon tires.
Please drop it. Thank you in advance.
Herk
HAM CALLSIGN - KC3FFW
Old 09-08-2012, 06:59 PM   #8
At only 5000 miles I would have the alignment checked. Should not be wearing like they are. This seems to be a fairly common problem. Too common. Forest River needs to fix the problem.
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
Nights camped 2012 - 35
Nights camped 2013 - 46
rkswyo is offline   Reply With Quote
Old 09-08-2012, 07:59 PM   #9
Forgot to mention, as far as tire brands go, I replaced my factory tires the day I brought it home with Maxxis. I upgraded to a 15" D load range as well. All the reviews I have read on the Maxxis are pretty positive. So far, so good for me!
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
Old 09-14-2012, 03:14 PM   #10
Coldsteel1986's Avatar
I'm having the same problem, so I just called my Dealer and he told me to take some pictures of the tires and axes' and he'll send them to company and go from there. Hopefully everything will work out.
2012 Salem 27 KRSS
WDS Curt with Curt Swaybar
05' Ford F-150
Lariat Supercrew 5.4L 3.73 gears
Trips 2012-x2
Coldsteel1986 is offline   Reply With Quote
21rr
