Old 09-29-2016, 10:50 PM   #1
Tons of questions
Hello. we recently bought a 2016 27RR 32' Grey Wolf toy hualer.
I have tons !! of questions. First I would like to say this is our first and we are learning as we go.
I was wondering . we cannot figure out why we can't get hot water ? We can't even find the hot water tank
What are tips on where to store the cushions while using the garage to has the kids' dirt bikes and 4 wheeler?
Where can I find a bracket to hook to my TV to align with the V bracket that is already installed?
Can you get tv channels once the TV is hanging? how do I get channels ?
We camped last weekend and we about froze!! We turn the heat on but it was still blowing old air set on 78!
I am so confused. can someone help me ??
thanks in advance
corrina3405 is offline   Reply With Quote
Old 09-29-2016, 11:23 PM   #2
mlatter's Avatar
First thing I would do is to verify that there is propane in the tank, and that you can at least get your stove burners working. Both the furnace and the water heater use propane so if there is none available, they won't work. Some water heaters also work on campground a/c but they would have to have the switch turned on which is usually located on the outside of the water heater, behind the access panel.
For the hot water, you will also have to verify that it is not in bypass mode, used for winterizing. Keep the questions specific and you'll get lots of answers.
2014 Cedar Creek 36CKTS Explorer
Xantrex Freedom SW3012 inverter/charger
2009 Silverado 2500HD Duramax Crew Cab short box
Demco Glide Ride pin box
Demco Hijacker Autoslide 18K hitch
mlatter is offline   Reply With Quote
Old 09-29-2016, 11:46 PM   #3
go outside, typically on the drivers side of your RV and look for black cover that has a cross hatch of holes in it. At the top will a little black tab to align with a slot so you can open the hatch. Once opened look in the bottom left corner and you will see an on/off switch. This controls your water heater on the 120 volt side, in other words when you are hooked up to shore power. Make sure you have water in the tank before you turn on or you will burn up the heating element.
are you on cable or are you operating from the antenna? If on cable, look at the receptacle where the coax is connected and make sure the little button is pushed that turn off the green led. If using the antenna push the little button to turn on the green led. There is a coax switch that selects either the cable connection (on the outside side of your RV) or the antenna input. Also, make sure you are connected to the cable input outside and not the satellite input. They are usually labeled. Once you get connected use the menu button on your remote to set up channels.
check your propane is on or your tanks are full. Try starting your gas burners on your range. It may take a while for the gas to get there
thanks in advance
See my comments above...
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
dalford is online now   Reply With Quote
Old 09-30-2016, 01:07 AM   #4
Moderators' Assistant
bikendan's Avatar
Didn't your dealer explain these things during the PDI?
Dan-Retired Firefighter/EMT
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 09-30-2016, 06:47 AM   #5
DW's Retirement Plan
DaGrinch's Avatar
My thoughts exactly! Hot water heater and furnace should have been 2 of the major systems explained during the PDI.
Dalford has explained how to correct those two.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life...
DaGrinch is offline   Reply With Quote
Old 09-30-2016, 08:25 AM   #6
The winter valves are under the bed/mattress, look for the round holes, the valves are there
I put them on the master bed
Should have received one with the unit, go back and ask for yours
There is a power switch (push on/off) on the panel on the ceiling by the TV bracket.
set thermometer to auto, then set here to temp, wait a min or so. make sure you have propane and the valve is on.
thanks in advance
I have the same unit
2015 grey wolf 27RR
2015 Chevy 3500HD
kcmusa is offline   Reply With Quote
Old 09-30-2016, 08:58 AM   #7
Here's a mounting plate that I used to get my tv to fit the V shaped mount
https://www.amazon.com/Monoprice-200...ilpage_o01_s00
2014 Chevy 2500 CC, Duramax
2017 Wolf Pack 25pack12 Toyhauler
polishdon is offline   Reply With Quote
Old 09-30-2016, 09:04 AM   #8
we bought it from an individual He went over so many things that I was just overwhelmed
