Old 07-26-2015, 11:14 AM   #1
Toyota Tundra measurements WDH
Here's my measurements of my 2012 Toyota Tundra DC with my 2015 19RR Camper loaded with 2/3 water and all our stuff less Gold wing.
Measured :Ground to fender
Unloaded-36" 1/2 inch frt
38" rear
Hooked up with no WDH
37" frt
36 rear
Using WDH 3 links
36" 1/2 frt
37" rear
No sway but can feel it a little when vehicle pass (P rated @ max psi) - no biggie just looking for some info on good/no good.
Had my first long pull 150 miles one way 8-9 mpg and very happy with both the Tundra and the 19rr. Greensburg,pa to mckean,pa (Erie KOA)
Erie KOA was very nice and peaceful cause they do not allow any motorized camp ground people haulers.
Thanks for any input.....
2006 Honda Goldwing
2012 Toyota Tundra DC s(sold)
2015 Cherokee Grey wolf 19RR Limited
2017 F150 Super Crew 3.5eb 5.5
bluewoo is offline   Reply With Quote
Old 07-27-2015, 12:04 AM   #2
I go RV'ing not Camping
jgourlie's Avatar
Looks pretty good to me...might be able to reduce sway with a friction sway control
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 07-27-2015, 01:56 AM   #3
Just a member
kandl's Avatar
Not too bad. It would be nice to get the back end closer to the unloaded numbers but some WDH systems will not fine tune to that extent.
Gold Wing? The Honda variety?
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge 1500 (the Beast)
kandl is offline   Reply With Quote
Old 07-27-2015, 02:22 PM   #4
Yup 2006 1800 kind
I do have a fric sway also
2006 Honda Goldwing
Old 07-27-2015, 04:06 PM   #5
Yep. Try and get more weight on the front (down a 1/2) and see where the rear settles in at. If the rear is pulled up 1/2 (37 1/2) then your truck will have the same level stance as it has unloaded. Your TT needs to be level traveling down the road as well.
2015 Viking 17FQ TV: 2005 Lexus GX470
bbrowncods is offline   Reply With Quote
Old 07-27-2015, 04:19 PM   #6
Cmmjmoore's Avatar
Looks really good.
2013 SP 240 Anniversary
Tundra CrewMax 5.7L in Pyrite Mica
Clark, Mary Jane & Max our German Short-haired Pointer
(2011-42)
Cmmjmoore is offline   Reply With Quote
Old 07-27-2015, 05:27 PM   #7
Thanks for the info -Ill try using one more link and see what It does.
Thanks Guys!!
2006 Honda Goldwing
Old 07-28-2015, 11:58 AM   #8
lynn brownlee's Avatar
38" rear
37" frt
36 rear
Using WDH 3 links
36" 1/2 frt
37" rear
Pull my 10,000 lbs TT to grande canyon from Alabama and to yellow stone no worries
lynn brownlee is offline   Reply With Quote
Old 07-28-2015, 02:15 PM   #9
AKA: 'tiredTeacher
awellis3's Avatar
Had my first long pull 150 miles one way 8-9 mpg and very happy with both the Tundra ...
Your measurements are good. The Tundra has a softly sprung rear end (because most folks don't haul stuff all day, every day) and P tires to improve the ride. So, your rear end drop is normal and you can forget it.
As soon as you put LT tires on your truck (I run Michelin), handling will improve.
As for your mileage, you must be ballin' the jack. I pull a heavier trailer with my 2010 and get 11 mpg driving around 60 mph.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 07-28-2015, 04:36 PM   #10
Im doing 65*70 mph in Pa - lots of hills- (Virginia is flat j/k) - not yet @ 40k on odometer yet so It still needs a couple more to get broken in. Dont forget I carry a Honda Goldwing in the camper too @ 822 lbs dry + fresh water 2/3 full @266 lbs not including all the sh*t that just has to come with the outing.
I also just had new tires put on the day before so maybe it will improve - doesn't matter to me just happy everything does what it should be doing and that's working well. I was going of off computer also so that's probably different than by hand calculating.
Thanks for the reply
2006 Honda Goldwing
toyota, tundra
