Old 04-03-2014, 01:48 PM   #1
TV
I am having trouble getting the tv to work in my 2014 19rr. I am not getting any signal. I have the cable attached to the tv and to the outlet marked tv on the ceiling. Is there a setting that has to be changed on the tv by chance? Does anyone have any suggestions? Do I need a special tv for RV's?
garytravel55321 is offline   Reply With Quote
Old 04-03-2014, 05:22 PM   #2
Booster on? Antenna up and rotated to find stations? TV input in the menu not set to cable?
Old 04-03-2014, 06:54 PM   #3
Tv - 2014 19rr
I turned the booster light on....but don't see any place on the ceiling to raise the antenna....I have a 2014 19RR. Is there a possibility there is no crank to raise it? Or rotate it to find stations? I am going to look at the book that came with the tv to check the proper setting when not using cable vs antenna.
Old 04-03-2014, 07:16 PM   #4
dan-nickie's Avatar
I'm sure you will have to go into the television menu, select air / antenna, and then run a scan 4 channels.
Sent from my DROID BIONIC using Forest River Forums mobile app
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 04-04-2014, 01:58 AM   #5
bikendan's Avatar
the booster button is ONLY for antenna over-the-air tv reception.
your PDI should've gone over the antenna and what kind it is.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 04-04-2014, 07:47 AM   #6
dstrauss2's Avatar
We had the same problem in our 21RR when we first got it. Tech fixed the problem at the Forest River rally last year.
With NO CABLE tv attached the booster must be on for the tv to get reception. The antenna is built in and does NOT go up, down or turn in any way. When you have a cable attached for cable tv the booster must be OFF. In our case, the problem was none of these things. The built in antenna wires were not connected properly when the camper was built. Tech opened up the box in the ceiling over the "living room" tv and made the correct connections for the "living room", "bedroom" and outside tv stations. It was a simple fix but we didn't know that that was the problem in the first place...
Hope this helps!
dstrauss2 is offline   Reply With Quote
Old 04-04-2014, 08:43 AM   #7
TV - Grey Wolf 19RR
Thanks for all your input....was as simple as running channel scan and setting the menu to AIR - ANTENNA.
