Old 04-04-2016, 02:11 PM   #11
camaraderie's Avatar
Ditto...On a standard car radio like this you FADE between front and back pairs of speakers (no matter where the 4 speakers are actually located).
Find the fader control by going into menu...then setup...then sound...then fader. Major pain to have to go through this every time. I would suggest adding a simple disconnect switch to your outside speakers.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 04-04-2016, 02:19 PM   #12
I'm really thinking about swapping out the radio as well. It's way too complicated for the # of times we use it. We also dry camp a bunch and having pull the fuse (to save on the batter) and then reprogram each time will not be fun.
John M
2013 GMC Sierra 2500DH CC, 4x4, D/A
2016 Forest River Vengeance 25V TT/TH
johnm1 is offline   Reply With Quote
Old 04-04-2016, 02:24 PM   #13
CDR USN Ret
On my XLR
The outside speakers are turned on/off via a separate rocker switch mounted in on the ceiling next to the radio.
My radio is in the garage area.
2015 XLR415AMP
2011 3500HD Duramax/Allison/90 Gal Aux
2015 HD Limited Low
DSQR is offline   Reply With Quote
Old 04-04-2016, 02:38 PM   #14
Naaa ... they didn't think that one through very well. No switches for the speakers.
John M
Old 04-04-2016, 03:05 PM   #15
As far as the antenna is concerned, if you have a round thingie that looks a bit like a flying saucer on your roof, that is the antenna.
Atchelitz is offline   Reply With Quote
Old 04-04-2016, 05:05 PM   #16
I installed a rocker switch in my 31V like DSQR said was in his XLR. Anytime you remove power from the radio it will go back to the default settiings a real pain. Single pole single throw switch
There is no crank for the antenna it is an onmi-directional unit up on top.
Marc Haught
15 Vengeance 31V
15 Ram 2500 6.4
MarcH is offline   Reply With Quote
Old 04-04-2016, 09:23 PM   #17
Sadly the roof is covered with icky cold white stuff ... as in snow. So I have no idea what the antenna looks like.
John M
Old 04-05-2016, 11:22 AM   #18
looks like these
Winegard RoadStar RS-3000 RV TV Antenna
Marc Haught
15 Vengeance 31V
15 Ram 2500 6.4
Old 04-11-2016, 11:57 AM   #19
The snow is finally gone ... again and I can see the RV roof. It is indeed the onmi-directional type antenna.
Thanks all.
John M
Old 04-11-2016, 12:07 PM   #20
Flybob's Avatar
Check manual, some auto/boat radios have-alive connection that provides power ( uAmps) to the memory/clock to keep it alive while disabling the other radio functions. If equipped, that line and general radio power are usually connected together during install. If you replace it, look for that capability.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
antenna, radio
