Old 04-13-2018, 10:39 PM   #11
I have a 40" in my toy hauler. I had to upgrade to the 200mm x 100mm PAW mount. Haven't had any issues.
wolfpack315 is offline   Reply With Quote
Old 04-16-2018, 02:44 PM   #12
26RR's Avatar
I have a 32 SMART TV for mine. Going to install it using a MORRyde Articulating Mount. Going to mount a piece of hardwood to wall, before installing mount. TV only 11 lbs, but understand wall should support the weight of TV, plus the TV Mount TIMES 5, when traveling!
2017 F250 XL, Supercab, 6.2L Gas w/Tow Pkg
2017 Grey Wolf 26RR Limited, Toy Hauler
2016 Cricket Mini Golf Cart[SIGPIC]
26RR is offline   Reply With Quote
Old 04-17-2018, 03:32 PM   #13
Maximum size TV?
Can any one of the 26rr owners tell me what is the dimension for the tv mounting location in the living area? In the wait for our TH to be delivered I would like to get ready with a TV set and possibly a mounting bracket. Is there any mounting brackets that the manufacturer includes with the trailer when new?
Cheers!
Dan
ToysNtrailer is offline   Reply With Quote
Old 04-17-2018, 03:43 PM   #14
26RR's Avatar
Cheers!
Dan
In my 2017 26RR, I got a VIZIO 32 SMART TV. I wouldnt count on the PAW mount to hold one that size, if left up while traveling. Some dealers will put in whatever you want, at extra charge of coarse. If boondocks is your thing, maybe a 12V TV. Im mounting mine with a MORRyde TV mount that swings out, and locks in place for travel. Support wall behind TV if you plan on leaving it up while traveling!!!
Old 04-17-2018, 10:55 PM   #15
rmac04401's Avatar
It depends on the year. I moved my tv to the back of the trailer. You can see it at pimp my 26rr. I have a 32 flat screen that I mounted an articulating arm mount to the wall fastened into a stud. Over 5000 miles and has not had issues with it. I did have to devise straps and Velcro to keep it in place.
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 04-18-2018, 09:56 AM   #16
I have an older 40" TV that I would like to use in that space above the cabinet Click image for larger version
Anyone knows what is the size (HxW) of that opening?
Old 04-18-2018, 01:07 PM   #17
rmac04401's Avatar
I have an older 40" TV that I would like to use in that space above the cabinet Attachment 168652
Sorry mine came with different cabinet its a early 2016.
2005 Honda VTX 1300
Old 04-18-2018, 01:13 PM   #18
I ended up buying a 32 inch and for now I kept the paw mount. Worked good feels pretty stable but not sure if I want to leave it while in transit. I did run wires through the wall behind tv to radio. Realy dumb placement on imput right above tv.
Dynomite4224 is offline   Reply With Quote
Old 04-18-2018, 03:49 PM   #19
26RR's Avatar
That photo, is just like my 2017 26RR. You will note the three colored plug ins on the right side (facing) wall. I believe with BIGGER than a 32 TV, you might have to use 90* Adapter plugs for each plug! If Im not wrong, the 2018 26RRs had these three plugs in the ceiling.
Better to measure, PLUS decide if youre going to install a articulating Mount. If so, you might consider supporting that back wall with hardwood, then attach mountthru that, into wall, specifically where the PAW mount was located.
Old 04-19-2018, 08:10 AM   #20
Our 26rr will be a 2019 model and will be delivered hopefully in a month or so. We looked at a 2018 unit on the lot and the salesperson said that most everything should be the same for the 2019, but who knows...?
I have planed a week-long trip for Memorial Day and I would like to get a TV set ready beforehand to take with us, that's why I would like to get a sense of the dimensions of that space.
