Old 04-06-2018, 11:57 AM   #1
TV mount/weight
I was wondering if the tv mount on the wall could handle the weight of a 32" tv??
Next Question; the radio is a furrion and it has a AV mode, so im guessing in this mode you can play movies on your tv using this radio as long as your tv has an av input you can connect to ??
What TV did you guys buy for your toy hauler and are you happy with it ??
GA82832 is offline   Reply With Quote
Old 04-06-2018, 12:40 PM   #2
Chaplain Kent's Avatar
I have been going over my trailer preparing for a long road trip this year. When I took down the TV, I noticed it was mounted to a 1 by 3 piece of pine. The mount looked secure until I checked the board. It was simply screwed into the thin wall material. I will be securing it to the cabinet.
The radio is also a DVD player and the leads are in the back of the cabinet.
Chummy V
Coachman Freedom Express 192RBS
2000 Ford Excursion 7.3
Chaplain Kent is offline   Reply With Quote
Old 04-07-2018, 08:32 AM   #3
i have a 32 in vizio had it in two trailers haven't had any problems
16grey is offline   Reply With Quote
Old 04-07-2018, 08:54 AM   #4
cavie's Avatar
Be sure the mount is secured to at least 1 stud. 32" tv will be fine. Any 32" TV of your choosing from Walmart or Best Buy. If you're a hardcore boondocker you might want to look into a 12 volt TV. Some TV's with an inline transformer in the power cord are 12 volt.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 04-07-2018, 10:04 AM   #5
Muletrain's Avatar
This "PAW" type TV mount that is installed in "most" campers is limited to 30Lbs or less.
Beyond that, you would need to trust the installer to have mounted it correctly.
Hope this helps.
Mule
Muletrain is offline   Reply With Quote
Old 04-10-2018, 09:49 AM   #6
I have a 32 inch Samsung mounted with the PAW mount that Muletrain shared, I haven't had any issues.
2019 Silverado 1500
No camper, currently
polishdon is offline   Reply With Quote
Old 04-10-2018, 05:23 PM   #7
Is the 32 inch tv the biggest possible? Also has anyone put an arm mount in to change angle or is it best to stick with the paw mount? Thanks
Dynomite4224 is offline   Reply With Quote
Old 04-10-2018, 07:51 PM   #8
i have a arm for our bedroom but it is only a 19 i took the paw system of and mounted where the paw was at so we could see it better when we were in bed angle with the paw was bad haven't tried with the 32 on the main living area have the paw there and depends on the modal you have i had the 32 in a 26rr and now in a 255rr and it is as big as i can go with either trailer
Old 04-10-2018, 10:25 PM   #9
rmac04401's Avatar
I installed one with arm in my trailer. Works fine. It has a 32” tv on it.
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 04-11-2018, 11:04 AM   #10
Ok thanks guys! Going to pick up new trailer tomorrow and was going to put in a big order on Amazon for weekend projects.
