Old 03-24-2009, 01:34 PM   #1
TV wiring -- diagram??
I've been to several campgrounds and my picture connected to the cable system in the campgrounds is not good. I'm certain I will need to check the wiring or "resimplify it".
Does anyone know how the Cherokee Wolfpacks (I have the 27DFWP) are wired for coax (RG6)? I have (2) connections labeled Satellite inputs on the back of the TH (toyhauler). I have (2) inside with one connecting to the antenna and one to the Outside inputs. I also have (2) outputs on the other side of the Toyhauler (regular door side) that are for connecting the TV outside. I am wondering how all of these connections hook together. My thought is the many splits are hurting the picture....
roamerr is offline   Reply With Quote
Old 06-07-2009, 08:13 AM   #2
We have a 396WP...Had the same problem with cable connections with ours. Had to go through every coax connection in the rig and re-do the connectors. Most factory installed connectors were barely connected and some came off the coax as soon as I touched them.
This means pulling each cable wall box and checking the connector to coax connection( i would get some quality connectors and re-do all). I also had to redo the connections that were connected to the flat screens. This was a little bit of a chore getting behind the flat screen cabinets.
All good now!
F350LEO is offline   Reply With Quote
cherokee wolfpack
