does anyone have one of these toy haulers that have a problem with the rear door I have a 2013 376 and the ramp door does not seal at the top I bet you could put your hand right in the gaps and I have not yet loaded anything in. I have taken it back to the dealer and they tell me that will happen and that maybe they could put thicker seal around the door. Do I just have to live with that or should it seal tight?
Depending on how your door is held closed. Look at the clamp that holds the door closed. Mine had about a half inch gap between the door and the rubber piece that pushes against the door. I took the clamp off, 4 bolts holding the hinges. Then bent the hinge the way the that was needed to put pressure against the door. My hinge was aluminum and only took two wacks with a hammer. Only had to do my top hinge as the others were ok. Reinstalled the clamp and I was good to go. My ramp is held against the camper with two clamps, each with three rubber parts that push against the ramp door.
We just picked up our 2013 306 Vengeance yesterday & just noticed the door issue this afternoon haven't loaded anything on it either. Please keep posted on what comes of this I'm disappointed with this issue
trailer is still at the shop but I looked at some other toy haulers and the latch system on the vengeance is poor to say the least they might have to add some other kind of latch system
Mine was like that and dealer resealed it but didn't change anything. Mine has the keyed latches not the longer bars that spread the load. Hadnt used mine either. But after loading my side by side it has closed up. Maybe built from the factory that way.
