Old 06-07-2016, 09:17 PM   #1
Water pump
So I've never used my water pump before, and this will probably be a dumb question... can I just turn it on and it runs when needed when it senses a pressure loss or is it more of a turn it on only for duration of pumping water?
drb1984 is offline   Reply With Quote
Old 06-07-2016, 09:19 PM   #2
raspivey's Avatar
Pressure on demand. It'll turn off on its own.
Old 06-08-2016, 07:48 AM   #3
Thank you
Old 06-08-2016, 10:24 PM   #4
rmac04401's Avatar
You do have to turn on button on control panel to on but it will only run when needed
2016 Grey Wolf 26rr
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 06-11-2016, 01:31 AM   #5
But won't it use up battery if left on? Unless you're hooked up to power.
LilRed7 is offline   Reply With Quote
Old 06-11-2016, 01:45 AM   #6
Witch Doctor's Avatar
Only true voltage is when it is running, other then that just the light that is on the the switch. Your CO detector will pull more then the light.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 06-11-2016, 10:06 PM   #7
My pump is working great. I know this because I have a leak and have to keep filling my fresh water tank and use that. I located the leak after removing the panel under the bath vanity, and it's seeping out of one of the t valves where the hoses intersect. I tightened everything I could. Thought it was a pressure issue but use a regulator and have a filter.
Vero Beach, FL
jbeal43 is offline   Reply With Quote
Old 06-11-2016, 10:09 PM   #8
Forgot to mention I noticed water dripping under the wheel well . That when I figured something was wrong
Vero Beach, FL
Old 06-14-2016, 07:08 PM   #9
I had water dripping by the wheel well as well. I thought that was just an overflow line from when I filled it up. It stopped after a short period after filling
Old 06-15-2016, 09:56 AM   #10
drb1984 the water dripping was most likely the overflow tube since it stopped. If it was a fresh water line leaking you would see water all the time when the pump is on and the pump would come on for no reason quite often.
Steve
Golden CO
2016 Grey Wolf 26RR Limited
92 GMC K2500 454
2006 Honda Rubicon ATV
zuterbru is offline   Reply With Quote
pump, water, water pump
