09-30-2016, 02:43 PM
What are you towing your 26RR with?
Looking at the 26RR. I have a 2013 F150 Supercrew 2wd, 5.0 V8, 3.31 rear gear, 144.5" wheelbase. Max trailer tow is 8000 lbs and gross combined is 13500 lbs. Max payload is 7100lbs. I have the factory brake controller also. I know the truck can do it with a good WDH but can it do it safely. I'm a big believer in not maxing out your equipment, especially when I have my family on board. I am interested in hearing all opinions but especially those that are doing it with a half ton. Does the trailer push or bounce you around? What about sway? How is the braking? If the brakes on the trailer failed could you stop it with just the truck brakes? You see where I'm going. Thanks.
09-30-2016, 03:01 PM
How much weight do you plan to haul in the 26RR? I'm pulling around 7200 fully loaded. My setup is a 2013 F150 3.5EB supercrew with 3.55. Your 5.0 will have no issues pulling but what is your payload again cause 7100 is definitely not the number? My payload sticker is around 1400 if I recall. A lot of tongue weight but when I put my two atv's it does drop it by a few hundred so around 875 when loaded so right around 12% tongue weight. I use a centerline TS wdh and it pulls great. Also I do keep the bed of my truck empty when the family is with me due to payload.
09-30-2016, 03:20 PM
You're right. 7100 lbs is the GVWR. Sorry, to many numbers swirling around in my head. Max payload is 1652 lbs. 7200 lbs would be the most the 26RR would ever weigh and it would not be that heavy every time we used it. I have been studying all the weight stuff. I would love to hear about your real world towing experience with your tow vehicle. Also, include what hitch you are using.
09-30-2016, 03:40 PM
I'll be picking up a 17 26RR next week. I will not have my WDH for the short 61 mile trip home. I plan on ordering one when I decide which one to get? Eaz-Lift with chains seems the better choice for adjustability. Cargo or no cargo? Or would that not make so much a difference in tongue weight.
09-30-2016, 05:35 PM
I'm pulling with a 08 F150 Supercrew 4x4, 5.4 Triton with 3.73 rear. I use the Anderson WDH and love it. It pulls great with the Anderson hitch it I don't have any issues. The trailer tracks and don't bounce. I'm sure the Ez-Lift is good also, but I'm impressed with the Anderson. It adjust quickly with a socket.
09-30-2016, 06:53 PM
I'm pulling with a 2011 Ram 1500 Quad Cab 4x4 4.7L ''mini hemi''...Husky WDH on "E'' rated General tires.. tows straight and no sway...with my Arctic Cat 4 wheeler loaded and gear at last trip...trailer weighed out at the CAT scale at 5875 lbs.
2016 Grey Wolf 26RR Limited
2017 Arctic Cat Wildcat Trail Limited
2019 Dodge Ram 1500 Bighorn Crew Cab
5.7 litre Hemi 4x4
09-30-2016, 07:09 PM
I'm pulling with 2006 Chev Silverado 1500 with Z71 package. 5.3l and 3.42. I installed Air lift suspension and also use Eaz WDH. We pulled our trailer from NE Minnesota to Ft McDowell, AZ and back last March. Generally it went pretty good. No issues. Obviously Once we started climbing elevation in NM and especially when we approached Flagstaff at 7000 feet it was pulling harder and did pretty good, but it was definitely working harder. On our trip home we decided to skip the climb and elevation towards Flagstaff by going down and around towards Tuscon. It added a couple of hundred miles, But was worth it. Before our trip I weighed my pickup, trailer and hitch weight fully loaded that included an Ultra Classic. My hitch weight was 825 and trailer weight was around 6200. GVCW was 12100. I wouldn't want to go any higher than that. We didn't set any speed records, but it did pretty good.
09-30-2016, 07:49 PM
Good to hear my Chevy will do the job. I've pulled a cargo loaded with 4 sport bikes for years with no problem.
10-01-2016, 04:27 PM
I pull with a 2010 Toyota Tundra 5.7L with tow package.
We're pulling a Rockwood MiniLite# 2304 GVWR of 4800 pounds.
Truck can tow 11,300 pounds per Toyota & 10,100 pounds
per owners manual so I always use the 10,100 figure. Truck runs
on Michelin LT rated tires. Primus electric brake system.
We use the Reese Distribution system and have had no
problems. Trailer tracks like a dream. Have put close to 30,000 miles
on truck & trailer in the past 4 years.
10-01-2016, 07:06 PM
I pull my 27rr with my 2012 1500 6.2L it pulls great. I've been coast to coast, up and down the steepest mountains in the US. I've added air bags and a larger transmission cooler. No problems at all. I am looking to upgrade TV but that's just because I will be upgrading TH in a couple years. Comparing F250 vs new chevy 2500.
10-01-2016, 09:14 PM
RiderBloke
The official specs on my 26RR state:
Unladen weight: 5110
GVWR:7715
Cargo carrying capacity: 2567 (I carry a motorcycle)
I tow with a 5.7 Tundra SR5 with a cap on the tray and tools in the back.
Equalizer hitch set up by dealer.
No sway, sits and tows well, Tundra has to be allowed to rev at 3000 or so up hills.
More truck would be my aim but this combo works well with or without the motorcycle.
Retired Intentional Interim Minister
Saginaw Valley BMW Riders
BMW Riders of Tampa Bay
Habitat Care-a-Vanner
10-02-2016, 05:34 PM
I pull our 26RR with an 08 Escalade ESV AWD (6.2, 6L80e, 3.42 rear) with a Pro Series 49903 WDH. Loaded weight is around 6800-7000 with 3 dirtbikes and a quad. I have no problems maintaining 65 on the highway and never drop below 55 on any hill. No sway, tracks well, and stops well with the trailer brakes.
2016 26RR and a 2018 OR371MBH
10-03-2016, 07:33 AM
(o˘◡˘o)
I'm pulling a 2016 26RR with a 2010 F 150 Platinum with 5.4, 3.73, max towing package and a Husky Centerline TS WDH. The trailer tracks and pulls comfortably. To me the aerodynamic front and relatively low trailer height help make the 26RR a good choice for a properly setup 1/2 ton PU.
A WDH that is properly set up is vital. Depending on what you are carrying there may be a substantial difference in setup empty vs. loaded. I re-adjusted mine (Ball height and tongue brackets were off) according to Husky directions and it is rock sold and feels very stable. I really like the hitch but had to get used to how high the truck and trailer needed to be jacked up in order to slide the bars into or out of the tongue brackets. Far better than dealing with chains though.
I did add Airlift bags and always run 20 psi towing or not. The progressive rear leafs were always a bit too mushy for me.
2016 Cherokee Grey Wolf 26RR
2010 F150 Platinum 4x4
10-03-2016, 07:40 AM
(o˘◡˘o)
Check the max tongue weight on your truck hitch before towing even a short distance without a WDH. For most hitches it's only 500 lbs without a WDH.
The 26RR has a substantially higher tongue weight and it's a lengthy trailer to pull with no sway control. The risk of damage to your TV far outweighs the cost of getting the hitch ahead of time IMHO.
10-04-2016, 11:53 AM
I purchased my 26RR last month and I tow it with a 2014 Toyota Tacoma Crew Cab long bed. I use the Equalizer WDH and it tows great. No bounce or sway. I have a lot of noise from the hitch but I am getting the lubricant that is recommended by the manufacturer of the hitch and will see if that helps.
10-04-2016, 05:08 PM
I have a 92 GMC K2500 with the 454 in it and the Anderson hitch. Pulls great and I love the Anderson hitch. I pulled it home with no WD and it did fine, not scary at all, only went about 20 miles. I would not do it with a half ton with the tounge weight. I did upgrade to a tekonsha Prodigy P2 controller, WHAT A DIFFERENCE! I had an el cheapo before but a smaller trailer. It was only full on or off, no in between, definately worth the upgrade wish I did it years ago.
Steve
Golden CO
92 GMC K2500 454
2006 Honda Rubicon ATV
10-05-2016, 01:03 PM
Pulling my 26RR with a 14 Ram 1500 Sport 5.7L Hemi w/ 8 speed trans and 3.92 rear end. I use the integrated brake controller on heavy electric 4.0 gain. Also have a Recurve R6 1200lb WD system. Pulls like a dream....no sway at all.
Replacing the truck this week with a 2016 Ram Rebel. Same 8 speed tranny, 3.92 rear gears and integrated trailer brake. Got the 32 gallon tank on this one....should be able to get an extra 75 miles between fill ups.
10-07-2016, 07:23 PM
Well I brought the 26RR home. It towed fine W/O a WDH the 26 miles home.
It wasn't level due to my trailer hitch being a drop instead of a rise.
06 Silverado Z71 Tow package. 5.3
I have a WDH coming by Brown Devil next week. Poor bastard that has to DR that to my porch :P (100lbs)
The sale before me was a 20ft being pulled by a van... Cut the telly pole tight before getting off the property.
Price Right in Dewitt, Mi did me right See Josh
Mike
10-19-2016, 04:55 PM
Finally got a pic:
10-22-2016, 10:18 AM
First time out in the Woods. 34 Deg this morning.
