Old 05-15-2013, 02:52 PM   #1
Where to put spare tire
I figure on putting it under the bed storage, where does others put it? The bed is in front, grey wolf 25rr.
2013 Cherokee grey wolf 25rr
06 F 250 5.4L gas
03 Honda vtx 1800c
R1campr is offline   Reply With Quote
Old 05-15-2013, 06:36 PM   #2
With all the cabinets we built, I figure I might as well leave it under the bed, as I think we'll have excess storage
Night_Wolf is offline   Reply With Quote
Old 05-16-2013, 08:39 AM   #3
lindy's Avatar
When we had our Rockwood 2604, I took the spare and put it in the bed of the trk up against the from and used a cargo strap to secure it there. Yes it took up a LITTLE bed space but with it standing up the way I secured it, it wasn't an issue. That and it took almost 75lbs off the rear bumper tube of the trl.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 06-02-2013, 03:03 PM   #4
dsrace's Avatar
if were me I would buy a spare tire carrier off ebay and mount it to your ramp gate. not to hard really just put the gate down and hold the tire up where it clears the base of the camper and ground. mark the location and find the studs in the ramp gate and bolt it to it. you might have to make a piece of 1/4" thick aluminum to span the studs to bolt the carrier too but not hard to do.
Utility Trailer Spare Tire Carrier #628
Triton Trailer UT Spare Tire Carrier 11830 | eBay
dsrace is offline   Reply With Quote
Old 06-02-2013, 03:40 PM   #5
KyDan's Avatar
I put my spare between the frame rails in front, under the pass thru storage area.
I drilled 2 holes thru the floor of the storage area and put a piece of angle iron inside
the storage area with 2 long carriage bolts sticking thru the angle iron and out the
underside of the trailer. I put those 2 bolts thru 2 lug holes in my spare and spun on
a large washer and 2 nuts. The lower nut is a nylock nut that won't vibrate off even
if it's loose.
It's a bit of a pain to get out but in nearly 5 years I haven't needed it!
On the back bumper it was in the way, in the weather and if I covered it, wasps
would ALWAYS build nests in the cover!
Peace!
Dan & Rita D
Blue Ox WD hitch
