Old 08-07-2012, 12:19 AM   #1
Why does my trailer groan?
Slow speeds, general driving - creeks and groans like a haunted pirate ship.
Is it my equalizer hitch?
2012 17rr
brookside is offline   Reply With Quote
Old 08-07-2012, 12:30 AM   #2
wyo700's Avatar
If you have an actual eqiulizer brand hitch. And does it do it especially bad when turn slow sharp corners. Yes mine does it very bad with those type of turns. It's just the way they are. They do make a lot of noise.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 08-07-2012, 01:24 AM   #3
showtime0022's Avatar
Its normal !!! Just use a lil lube might help alittle
showtime0022 is offline   Reply With Quote
Old 08-07-2012, 03:15 AM   #4
Iggy's Avatar
Because its hurting?
Iggy is online now   Reply With Quote
Old 08-07-2012, 03:59 AM   #5
papap's Avatar
When I had a travel Trailer mine groaned also. Greased all joints with never seeze. never groaned again.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 08-07-2012, 04:58 AM   #6
Old car's Avatar
If you have an Equalizer hitch--it will do that. Check out their website for some teflon pads--Bracket Jacket--they say it helps. I have not tried them.
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
Old car is offline   Reply With Quote
Old 08-07-2012, 07:14 AM   #7
Our Equilizer hitch made all sorts of noise turning at slow speeds last year when it was new. It got a little better as things wore in a bit, but I ended up getting the Bracket Jackets from Equalizer as well as their lube at the end of last year. I dont know if it was the jackets, the lube, or the combination but they did the trick and it is much much quieter now.
2011 Surveyor SP260
2012 Ford Expedition
chof16 is offline   Reply With Quote
Old 08-07-2012, 07:52 AM   #8
DDC
DDC's Avatar
Never been on a haunted pirate ship but hitches can make a lot of noise, grease works for a while but it always comes back.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 08-07-2012, 08:36 AM   #9
Its probably an old age thing. Thats what I blame about everything.
Chicken Legs is offline   Reply With Quote
Old 08-07-2012, 09:46 AM   #10
camper_Lucy's Avatar
2012 17rr
First, never lube all the joints on an Equalizer hitch, the metal on metal is what gives you the sway control.
Grease the joints in the hitch head only.
To reduce the noise, which by the way tells you it is working correctly, you can do two things, add Teflon pads to the L brackets, make sure the sway bars are parallel with the trailer frame when installed (this is the one that I see wrong the most and the angle creates a lot on noise).
FYI, Frequently Asked Questions
Ours always made a little noise even with the pads and correct alignment.
2011 GMC 3500HD 4x4 Crew DRW Duramax
Pullrite 20.5K
2012 Sierra 365SAQ
2006 Police Roadking FLHPi
camper_Lucy is offline   Reply With Quote
