Old 06-26-2016, 11:10 AM   #1
A/c issue
Just returned from a trip to Florida. On our way back the front air conditioner quit working on our 2015 351 DS Georgetown. After investigation I found that the breaker was tripped. I reset the breaker and it seemed to work fine. However It continues to happen periodically only when running off the generator. It doesn't occur when plugged in. Any thoughts?
Gohawks is offline   Reply With Quote
Old 06-27-2016, 05:09 PM   #2
Head Rambler
There are several threads going on right now about running (or not) of A/C's on generator's in your rigs.
It boils down to the generator is not big enough.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 07-07-2016, 09:47 PM   #3
Is it a shared breaker with another one (ie split breaker)? Sometimes they'll heat up during the summer months and pop like your saying.
KansasFR3 is offline   Reply With Quote
Old 07-15-2016, 07:53 AM   #4
I have a Georgetown 378 and was having the same problem initially until I realized that my water heater was on .shut it off and now i run front Ac and refrigerator no problem. What it boils down to is generators are not big enough.
Gualter is offline   Reply With Quote
Old 07-19-2016, 06:52 PM   #5
cawffeeguy's Avatar
Correct...a 5500 should be strong enough on its own but when other things are drawing off it too, then that's what happens most often.
Cawffeeguy
2015 Georgetown 270s
cawffeeguy is offline   Reply With Quote
Old 07-19-2016, 08:50 PM   #6
If its just the AC breaker tripping (20amp I think), then that breaker might be weak and/or over heating. I had to replace my AIVbreaker during the first year of ownership. Breaker was one of those dual ones in one size. My AC shared with the main (30 amp) and would get hot to the touch. My box had a spare slot unused. Went to Home Depot and bought two regular single breakers. 30 amp to replace my main and a 20 amp for the AC. No problems since for 5 years.
2011 Sunseeker 3170DS - 30,000 miles explored
funfinder5 is offline   Reply With Quote
