Old 09-19-2016, 11:12 PM   #1
Adding a fire extinguisher in the Propane Tank Bay
There is a lot of great discussion on the importance of adding more fire extinguishers and replacing the small ones that come with the RV with bigger ones.
I finally installed an upgrade to put a fire extinguisher in the bay with the propane tank. There are two reasons to add a fire extinguisher here:
1. The fire could start in the propane tank bay, perhaps when filling.
2. The propane tank bay is the only unlocked bay in my RV, so it can be accessed by anybody who knows there is one there.
I installed an old ABC extinguisher that buckles in. Being old, it is less likely to be stolen. But, I plan to keep it in the Berk while being stored, and installed in the bay when we go camping.
The pressure gauge reads normal, and hopefully the motions of the RV will shake it up to prevent clogging.
BTW, I did replace the small Forest River fire extinguisher by the passenger seat with a larger one from Costco. The Costco one only hung from the top and bounced around, so I put in a strip of velcro to hold it in place. I'm sure that anyone stress by a fire will be able to disconnect the velcro.
I do have a couple of other fire extinguishers. The original Forest River one is in the bedroom, and the bay for the slides and equalizer levels has one.
Gordon Sick, Calgary
2015 Berkshire 34QS
2005 Acura EL (aka Honda Civic)
gordonsick is offline   Reply With Quote
Old 09-20-2016, 02:20 PM   #2
GSD_Gunner's Avatar
2 thoughts. If I were to put an extinguisher in the propane bay, I would probably do a Halon or HFP flood if there's a worry about a fuel fire at the tank. Second, if that's an old extinguisher with questionable integrity of the gauge, look for a fire extinguisher shop near you and take it in. They'll discharge it and refill for a nominal price. You'll then know exactly when it was last serviced and if there's any issue.
2017 XLR Boost 27QB pulled by a 2014 Ram 2500 Cummins
GSD_Gunner is offline   Reply With Quote
Old 09-20-2016, 02:41 PM   #3
jeff
jeff64's Avatar
I always like the idea of extinguishers close at hand, 1 in bedroom, near the exit and away from a probable fire/ fuel source. Just me!
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 09-20-2016, 02:43 PM   #4
well, it is better than nothing but my thought was sort of the same. How can I get close enough to the propane bay if it catches fire to get the extinguisher?
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 09-21-2016, 08:05 AM   #5
Sc00ter's Avatar
Dry chem extinguishers will actually settle and compact with the vibrations from driving. From time to time flip the extinguisher upside down and tap on the side. You will hear and feel the powder loosening up inside. Otherwise it can compact and fail to dispense when needed. Smart idea. I like it.
2015 puma 295bhss
2009 ram 3500 6.7l ctd
Sc00ter is offline   Reply With Quote
Old 09-21-2016, 08:45 AM   #6
DDC
DDC's Avatar
I think that if there is fire at or near the propane tanks I would spend my money on faster running shoes
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 09-21-2016, 09:06 AM   #7
bubbles's Avatar
Isn't this like putting a hand held extinguisher in the bunker where the dynamite is stored?
Old 09-21-2016, 09:07 AM   #8
grumpy0374's Avatar
If your propane tank catches fire it's gonna go "BOOM". Not anywhere enough time to get to or use a fire extinguisher.
Your placement though is a good idea as that compartment is never locked giving good access.
And if your propane tank ever does catch fire, get everyone AWAY from it. Don't go running toward it. If its being filled, than if it goes than the other filler tank is gonna go with it.
Grumpy
Steve & Cheryl + Charlie & Casey, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
Camping trips this year so far...8
Days camping...75
grumpy0374 is offline   Reply With Quote
Old 09-21-2016, 09:23 AM   #9
Filthy Beast's Avatar
From what I see, the only downside is if the propane tank is the thing on fire. There are a lot of other things that can burn that it would be nice have one handy outside.
Goody Two Shoes and the Filthy Beast
2008 Chevy Silverado 2500HD
Duramax and Allison 6 speed
2012 Wildcat 282RKX
You can't make things idiot proof, you can only make them idiot resistant.
Filthy Beast is offline   Reply With Quote
Old 09-21-2016, 09:30 AM   #10
Canadiancrew's Avatar
We got told this when we had a boat inspection. They suggested the best way to mount them is on there side. Does not eliminate settling and packing of the material but sure helps. Either way yes we need to shake up the extinguisher from time to time. It's not so critical in the house but a boat like a trailer is subject to vibration and bump packing the material.
On another note I understand that compartment is unlocked but I would prefer to have it someplace else to be able to go at the fire with the extinguisher in hand. But then like DDC said if the fire was in there a pair of good runners might be a better investment.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
Canadiancrew is offline   Reply With Quote
propane, tank
