Old 01-12-2013, 08:07 AM   #11
Yes a suction gun will work but my experience with both I would choose the screw on valve for the quart oil container. There's no hose to drip or clean up when finished. Each time you remove the hose to get another 1/2-qt refill, and that would be 12 times, again chance to drip and create additional messes. I'm a bit of a neat guy when it comes to this stuff and don't like the oil except in the engine. Either choice would work.
JMTCW
TeJay
TeJay is offline   Reply With Quote
Old 01-12-2013, 09:07 AM   #12
Oklahoma Proud
MillerTime's Avatar
Yes, I make a mess on the floor quite a bit, always put towls down, or wipe/spay off customers vehicles if fluids get spilt on them. I work on commision, so I tell the boss I dont get payed to keep the place clean, there is someone making minumum wage for that- and really he doesn't care when I'm making him money!
Old 01-15-2013, 10:33 PM   #13
On mine I remove the inter cover pull the filler tube out of the valve cover add the oil I need replace tube and cover.I change oil twice a year with filter.
trell is offline   Reply With Quote
Old 01-16-2013, 06:32 AM   #14
CLASS "A" Senior Member
cfsoistman's Avatar
Multi-Use Transfer Pump
Cheap easy way to add oil when needed or when I change my oil. I just use a 6 ft ladder with a paint tray shelf to set the oil container on and pump away. The neighbors look at me kinda strange but it works. I just store it in a zip lock bag in the shed.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
