Older thread, I know.
I bought a used Roadmaster Falcon 2 tow bar from eBay. It was only a year old, but covered in dirt. I spent an hour cleaning it up, now looks great and works perfectly. Paid less than 1/2 price compared to a new one.
I then found a Roadmaster Even Brake 9400 on eBay for $450. These are $1200 new on Amazon, $1400 elsewhere. I did have to order a breakaway switch setup as it wasn't included, and a new brake pedal clamp. About $100 worth of gear. Got it hooked up and tested. Works perfectly.
There's always some risk involved buying used gear, and even dealing with eBay. But eBay now has a 30 refund policy and they use PayPal for their transactions. I've had to use this service before, and it was quick and easy to get a refund. As for the used gear, I'm an aerospace tech, and have no problem tearing things apart to verify everything is in good working order.
Installing the Even Brake system was quite easy on our Jeep. Took maybe 40 minutes as I wanted to hardware the system, and removed a dash access panel to hide all the wiring when complete. If I had to do that again, probably only take 10 minutes next time now that I've figured out the optimal setup.
So it pays to shop around. Lots of people buy these systems new, and don't use them a lot. See lots of used motorhomes with low miles. Bargains can be had if you're willing to shop.
