Old 01-18-2015, 09:37 PM   #1
Frank & Eve's Avatar
Annual maintenance to do list.
What's on your list ? Check and seal roof seems, grease sildeout gears, spray silicone lubricant on slide seals, change oil in generator and check air filter, change water filter....
Frank & Eve is offline   Reply With Quote
Old 01-19-2015, 08:19 AM   #2
Sanitize water hose and fresh water holding tank, check air pressure in all tires, check all sidewall caulking (even around side marker and tail lights), flush out water heater again and check anode rod (if you have one), lube black & grey tank pull rods, inspect and clean AC cooling fins, inspect all LP lines for leaks and check LP tanks for fullness, check for any plumbing leaks, a good exterior wash, a good interior cleaning, wash windows , vacuum screens including those in roof vents...
Old 01-19-2015, 08:35 AM   #3
TURBS's Avatar
Wash the roof if you didn't do it in the fall.
Old 01-19-2015, 10:01 AM   #4
Here's a few more: Check water level and charge battery, check water heater pressure relief valve, lube door hinges and all locks with lock lube, lube TV antenna ‘O’ ring, lube swing out steps, give your Fire extinguisher a shake, install fresh batteries in smoke detector, remotes, etc.
Old 01-19-2015, 10:49 AM   #5
That's what I'm talking about ! Going to make a check off list. Thanks
Old 01-19-2015, 11:34 AM   #6
RudysWorld's Avatar
Would like to see everyone's check off lists to update mine.
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
Old 01-19-2015, 12:36 PM   #7
harleyguy's Avatar
I also check under my trailer and fill any areas with expanding foam where mice or other critters can come in
harleyguy is offline   Reply With Quote
Old 01-19-2015, 05:23 PM   #8
you might consider wheel bearing maintenance or inspection and grease suspension
palmetto rogue is offline   Reply With Quote
Old 01-20-2015, 09:50 AM   #9
Does the big foot levelers need any maintenance?
Old 01-20-2015, 10:20 AM   #10
Here's what we have so far for your.....
Motorhome Yearly Maintenance
# 1 Wash Roof .
#2 Check all roof seams and seal if needed.
# 3 Grease slide out gears. #4 Lubricate slide-out seals with silicone.
# 5 Change oil and filters in generator.
#6 Change water filter.
#7 Check air pressure in all tires and airbags.
# 8 Check all sidewall caulking including taillights and markers.
#9 Flush out hot water heater and check anode rod.
#10 Lube black and grey tank pull rods and inspect sewer hose.
#11 Inspect and clean air conditioning cooling fins. #12 Check LP lines for leaks and tank fullness.
#13 Check for plumbing leaks.
#14 Thoroughly clean inside and out including screens and wash windows.
#15 Check water level in the batteries and charge if needed .
#16 Check water heater pressure valve .
#17 Lube doors hinges .
#18 Lube all locks with lube lock.
#19 Lube TV antenna O-ring.
#20 Lube swing out steps if you have them.
#21 Shake your fire extinguisher.
#22 Install fresh batteries in smoke detectors and remotes.
#23 Check under home for holes and filled with expanding foam to keep critters out .
#24 Check wheel bearing.
# 25 Inspect and grease suspension.
Anything else we need to add to the list ??
maintenance
