Old 10-12-2016, 10:54 PM   #1
Arctic package
We have a new Sunseeker with the Arctic package. Trying to use it tonight as it is supposed to get down to 28. Flipped the switch to on but the light doesn't light. I know the pads have a thermostat in series but shouldn't the light be on? I have searched the Internet and some say yes and others say it will only light when the pads are operating. Anyone know for sure
Murphy55378 is offline   Reply With Quote
Old 10-12-2016, 10:59 PM   #2
Iwannacamp's Avatar
Arctic package
Most of these have a temperature sensor where it comes on at a set temp. If you are running heat then it may not be cold enough down there.
Our new 5er 10-26-16
Days camped 2016 8
Old 10-12-2016, 11:07 PM   #3
Iwannacamp's Avatar
BTW you can google arctic PAC and read more than you want to know
Days camped 2016 8
Old 10-13-2016, 12:24 AM   #4
Iggy's Avatar
Here is a old document from FR about Artic Pak
I do not believe the light come on until the temp drops below the low point.
I guess I will have to test next time I'm in my rig.
2012 Georgetown XL - 378TS
Old 10-13-2016, 12:36 AM   #5
The light will be ON when you turn on the Switch! This indicates you have 12V power to your Heaters! The Thermo will auto take over from there! Make sure you have Fluid in all your Tanks Before turning on the Heaters! Youroo!!
Old 10-13-2016, 08:40 AM   #6
SeaDog's Avatar
Yes the light should come on maybe you have a fuse blown. The doc attached by Iggy tells it all.
Retired Navy
Jake my sidekick (yellow Lab)
2006 F350 6.0
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 10-13-2016, 08:43 AM   #7
Mr. Dan's Avatar
I don't have a Sunseeker... but my light is on when the switch is on - regardless of the temperature.
SEARCH is your friend!
Nights Camped: 2013 = 49 / 2014 = 74 / 2015 = 74 / 2016 = 85 / 2017 = 00; booked = 42
Old 10-14-2016, 01:45 AM   #8
benagi's Avatar
When my light went out we were in for some other warranty work and we had them check to see why the light was out. Turned out to be a loose wire by the switch.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 10-14-2016, 04:27 AM   #9
Witch Doctor's Avatar
Light should come on as everyone has pointed out, those rocker switches bulbs will burn out also. I know it happened to me, I now carry an extra one. Got a multi meter check the back of the switch for power.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
