Old 10-16-2016, 07:06 AM   #1
gizmo98's Avatar
artic pak problems
Hi i have a forest river class c motorhome 3051s 32 feet with the artic pak
I turned in on the other day and no light came on power panel temperature was 2 degree celcius 40 degres f
i checked the fuse it s good any suggestions would be helpful
Rob & Elizabeth Sweeney
Having fun in our Forester Gump (2015 3051S forester)
gizmo98 is offline   Reply With Quote
Old 10-16-2016, 09:36 AM   #2
SeaDog's Avatar
The tank heaters if you have them installed have a thermostat that controls the heating just because it was 40* outside it may be no where near that where your tanks are mounted if you have been using your coach heat. Some heating elements are designed to come on when the liquid in the bottom of the tank reaches 43* and off around 64*
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 10-18-2016, 03:12 PM   #3
Iggy's Avatar
Here is a general docs on the Artic Pak
2012 Georgetown XL - 378TS
Iggy is online now   Reply With Quote
Old 10-18-2016, 06:29 PM   #4
Mr. Dan's Avatar
My unit is not like yours but my tank heater light comes on when I flip the switch regardless of the temp. My switch for the propane side of the water heater had a bulb but it didn't come on when the switch was flipped although the propane side worked. I looked behind the switch and found there was no ground wire for the bulb leg of the switch. I added one. Now I have a lighted propane switch.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 28; booked = 32
