Old 06-15-2014, 06:36 PM   #1
CampTBug's Avatar
Atwood Hot Water Heater Temp adjustment??
We just got a 2015 Forester 3011DS and took it out over the weekend. Everything worked great overall. This is our first MH so we are learning about all the components. We've had 3 TTs previously so we are familiar with most of the major things or so we thought. We noticed the hot water heater is constantly firing up to keep the water hot. (We had to use propane instead of electric to avoid exceeding 30 amps considering all we had running.) I read the booklet to see if we could turn down the temp as the water is steaming hot but I could not find a lever or round knob as suggested in the manual. Can we adjust the temp on this HWH? It's the Atwood unit now in the 2015 units. If it's adjustable, can someone please point me in the right direction of where to look for such? I did a search but couldn't find anything on the Atwood units for 2015 models. Thanks!
CampTBug is offline   Reply With Quote
Old 06-15-2014, 06:55 PM   #2
Ford Idaho's Avatar
I have an Atwood and there is no way to turn it down.
They do make the model G6A-7 which is adjustable for 325.00 USD.
RV Appliances NEW ATWOOD RV/MOTORHOME 6 SIX GALLON WATER HEATER MODEL: G6A-7 RV Water Heaters | RV SALVAGE PARTS AND ACCESSORIES AND SERVICE. EAST BERNSTADT, KY. LONDON AND SURROUNDING AREAS. TN. OH. WV. SHIPPING AVAILABLE. ORDER ONLINE. KOA. | vison
Old 06-15-2014, 08:58 PM   #3
CampTBug's Avatar
Thanks for the quick reply! We will just have to live with super hot water!
Old 06-16-2014, 05:27 AM   #4
fonzie's Avatar
You could try to adjust by-pass valve open allowing some cold water to mix with hot water.
Name:	water heater bypass.jpg
Fonzie
Old 06-16-2014, 06:30 AM   #5
B and B's Avatar
A residential anti scald valve could be installed on the output side as well. We have one at home that keeps the temp reasonable. You can get them as low as 100 degrees.
Sent from my Z30 using Forest River Forums mobile app
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 06-16-2014, 06:19 PM   #6
CampTBug's Avatar
We will try these suggestions. Thanks for all the great advice!
heater, hot water, water, water heater
