Old 08-26-2016, 10:12 PM   #1
sgtlm17's Avatar
Blurry sideview camera
I have the backup camera with side camera option. . Traveling today I noticed the drivers side camera is foggy or blurry in appearance. . I cleaned the outside lens so that's not the problem. . Has anyone experienced this. If so what did it turn out to be.
2016 Forester GTS 2801QSF
RVHabit.com
sgtlm17 is offline   Reply With Quote
Old 08-27-2016, 07:11 AM   #2
No-Fish's Avatar
Ive got the same problem, Rt side view fogged up, Ive got another camera coming from RVS, Going to replace it myself. I just did want to send the RV to the dealer for a couple of weeks. All I had to do is buy the camera from RVS, then return the old one for a refund.
No-Fish is offline   Reply With Quote
Old 08-27-2016, 07:29 AM   #3
ilmor's Avatar
Could be moisture that got inside the camera.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 08-27-2016, 07:53 AM   #4
Citrus County, Fl.
GL1800Rider's Avatar
I have had the same problem since day one. Starts out ok but after 30 minutes or so driving they fog up. Seems worse during high humidity. I have got used to it by now and just rely on the mirrors instead of the camera which everybody should be doing anyway. Coming back from North Carolina in May I had no issues with this.
It seems to be an issue with the mirror mounted mirrors which have been discontinued. The new cameras are mounted on the side of the coach. I wonder if the new mounting location has solved the issue.
Another thing, I always keep the rear view camera on when driving so I can keep an eye on the toad. Last trip we drove at night for the first time and the brightness was so distracting I finally shut it off. There does not appear to be a dimmer for the screen which would have been nice.
2016 Forester 3011DS
2015 Toyota Corrola S toad
99 Terry 31G
GL1800Rider is online now   Reply With Quote
Old 08-27-2016, 07:59 AM   #5
sgtlm17's Avatar
GL 1800Rider
I have the cameras on the side of coach so the new location didnt solve the problem. I was hoping I could take camera apart and replace a gasket or seal. I will have to look closer at it today.
Lou
RVHabit.com
Old 08-27-2016, 09:55 PM   #6
No-Fish's Avatar
hey GL1800
I had the same problem w/ the rear cam being to bright, I played around w/ the monitor and turned the brightens down for night driving, the cam that is messed on mine is mount low on the side..I even tried a blow dryer, no luck
Old 09-02-2016, 11:53 PM   #7
sgtlm17's Avatar
I pulled camera off and opened it up. . It was full of water. So I emptied the water and tried a hair dryer but it just kept fogging up when I removed heat. . I have it in a bag of rice for a few days to see if that will get rid of the moisture on the lens. .
RVHabit.com
Old 10-14-2016, 01:23 PM   #8
sgtlm17's Avatar
all attempts to clear camera of moisture were unsuccessful. I contacted my dealer who sent me a new side view camera. I installed the camera and all is working great. Install took 15 minutes.
RVHabit.com
Old 10-14-2016, 09:25 PM   #9
Can anyone advise how I can get into the camera that is attached to the mirror? I opened the rear one and removed the moisture and it helped. I don't want to damage the mirror, as I did not see an obvious way to open it. Thanks!
Steve & Debbie Russell
2013 Sunseeker 2900
TelescopeClinic
Starry2some is offline   Reply With Quote
Old 10-14-2016, 09:35 PM   #10
sgtlm17's Avatar
Your not talking about getting into the screen on the windshield in the cab?
RVHabit.com
