Old 07-30-2019, 11:06 PM   #1
Dodge Guy's Avatar
Built in CO/LP detector
Anyone replace the built in detector? I know the free mounted ones have a 7 year life but what about the built ins. IIRC I think mine shows a redlight or something that said it bad. I do have the wall mounted one in he bedroom, but would like to replace the built in so it is working properly (the LP portion works fine).
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 07-31-2019, 11:41 AM   #2
NXR
NXR's Avatar
I installed a battery-powered Nest Protect combination CO/smoke detector near the Norcold refrigerator and it's connected to our Wi-Fi hotspot. If there is a CO or smoke alarm it will alert you remotely via your smartphone if you're away. If you add a Nest Camera it also will turn the camera on and start recording if it happened to be off.
Ray
NXR is offline   Reply With Quote
Old 07-31-2019, 11:59 AM   #3
Flybob's Avatar
The built in CO/Propane detectors have about a 5 yr life. You need to be careful when replacing them as some are simply a dual detector and alarm and some have built in circuitry that deactivates a solenoid to shut off the propane when it alarms. If you have the later, you need to replace it with a unit that will activate the solenoid then there is no alarm. Motorhomes usually have the solenoid equipped alarms.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-31-2019, 12:02 PM   #4
I replaced my combination LPG/CO detector with separate units. CO/Smoke detector at ceiling for the lighter than air CO and an LPG only detector at the old location for the heavier than air LPG.
This way I only have to replace whichever one fails, not both at the same time.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 07-31-2019, 12:26 PM   #5
Just replaced my combination detector with a propane only detector. Then installed combination smoke/CO detectors in the living and bedroom areas. Saved over $100 by purchasing on Amazon over the RV dealer. Very simple to replace. Two screws and two wire nuts.
RStormC is offline   Reply With Quote
Old 07-31-2019, 06:33 PM   #6
Dodge Guy's Avatar
Yes, mine has the shutoff solenoid. I also was thinking of just getting an LP only defector and installing to combo smoke/CO detectors.
Old 07-31-2019, 06:57 PM   #7
Flybob's Avatar
I haven't looked to see if that would save any money or hassle. Because propane only are usually less in demand price may actually be higher. Good Luck
TST Tire Monitors
2 100W solar panels
Old 07-31-2019, 09:40 PM   #8
I replaced my LP/CO detector with an LP only and installed a Kidde CO detector on the wall. The Kidde CO detector has a digital readout and a built-in battery with a 10 year life. It's a standard residential unit available at most home improvement and hardware stores. The LP detector was a standard RV unit, an exact replacement for the LP/CO unit. I got tired of false alarms. Since I changed to separate detectors I've had no false alarms.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
Old 08-01-2019, 03:16 AM   #9
DouglasReid's Avatar
We too started getting false alarms so I changed all three.
1. the LP detector at the base of the cabinets in the LR.
2, the Fire/smoke detector above the door
3. and the CO detector in the bedroom. Here like thie previous poster I bought a Kiddie 10 year battery model.
End of false alarms.
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
