Old 04-24-2007, 10:58 AM   #1
cable tv changeover
I have a forester 2941, it has the cable tv hookup in the rear compartment. where do I unplug the antenna and plug in the cable? probably a simple switch I haven't discovered yet!
casinogoer is offline   Reply With Quote
Old 04-24-2007, 08:13 PM   #2
welshman599's Avatar
Send a message via MSN to welshman599
Well now that is an interesting question! Mine is still locked down for a couple more weeks, but I'll check when I get into it... I assume they use a simple junction block to allow either to be used, but can't say for sure.
welshman599 is offline   Reply With Quote
Old 04-25-2007, 07:11 AM   #3
If it's like most hookups you just turn off the power to the antenna amplifier.
02 Chevy 2500HD Duramax ,Ally 5 speed, 3.73 gears :Equalizer Hitch
2006 Flagstaff 829FKSS
flagstaff is offline   Reply With Quote
Old 04-25-2007, 02:58 PM   #4
I agree. There should be a switch on the main hookup. A red LED indicates power to the signal amplifier. Move the switch and the LED will go out. The amp turns off and passes the cable through un-hindered. If you leave it on it REALLY jacks with the cable signal.
aintgotnun is offline   Reply With Quote
Old 04-25-2007, 05:58 PM   #5
milzat's Avatar
Not quite sure what you're asking. I wouldn't think you'd have to un-hook the antenna to hook up the Cable.
If you mean the Cable(in) connection, most Cable/Satellite connections on the exterior of the RV are similar to the photo above. One side will be for Cable(in), and the other side will be for Sat(in).
milzat is offline   Reply With Quote
