Old 08-15-2016, 01:42 PM   #11
Originally Posted by grhodes50 View Post
I had ours built about 5 years ago and I've been very happy with it. It's withstood some very strong wind gusts (up to 80 mph) and sustained winds during storms here in Oklahoma. There are 8 hurricane anchors plus 20 rebar steaks to hold it in place.
It's 18' wide x 41' long x 12' sidewalls.....approx. 15' in center. I added a 12' wide x 20' long lean to on the side for our pop up. You could park your tow vehicle there.
When I had it built we owned our LaCrosse tt, but it houses our new 2017 Crusader 5'er perfect. The trailer is listed at 12' 9" tall and it's wide enough to open slides on both sides.
I also had a 100 amp breaker box, with cut off, installed next to the meter on our house. Then they ran a line out to the RV port to an electrical box like you find at a campgrounds with 50 amp, 30 amp and 20 amp plugins.
I hope this helps you.
Here's pics;
You said you had it built. Do you know what company the carport is made by?
Brian217 is offline   Reply With Quote
Old 08-15-2016, 01:46 PM   #12
mikkeeh.......
They are mobile home anchors screwed into the ground. The one's I have are similar to the picture below, but I was thinking there were more "blades" covering about 3/4th's of the shaft.
They are attached to the rail that runs along the ground as in this picture.
The nut you see on top of the rail is welded to a 2' long rebar and hammered into the ground. Those are the rebar stakes I referred to.
Are the anchors and rebar set into a concrete footer, or just dirt?
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2016: 38 nights camped
Teamfour is offline   Reply With Quote
Old 08-15-2016, 01:49 PM   #13
Mine is 18 foot wide with 13 foot side walls and 40 foot long
If not camping, I am Sailing
JohnVtx is offline   Reply With Quote
Old 08-15-2016, 06:41 PM   #14
I am ordering mine next week .... from Graceland on Guignard ... Tony Milam is great to work with. $5713.20 . The main part is 18' X 41 ' (15 ft high in center). Then a side portion will be 12' X 41" (9 feet high).
Alec
Eastover, SC
Prior Campers
1996 Coleman Sun Valley (1995 - 2002)
2017 Forester 3011 DS (2016 - Present)
SharpPI is offline   Reply With Quote
Old 08-15-2016, 07:45 PM   #15
grhodes50's Avatar
I would have to dig out all the paperwork. Sorry, but that was 5 years ago.
I do remember checking with 3 or 4 companies locally. They are just middle men and all pretty much use the same supplier, so quality of material is usually the same. Check to make sure though. Then see which one will give you the best service and price.
A traveling crew installed it. They showed up one evening around 7:30 and worked til dark. They were done by noon the next day.
They are installed directly into the ground. No concrete.
Gary & Trish
2016 Nights Camped - 9
Old 08-15-2016, 07:48 PM   #16
grhodes50's Avatar
Alright !!!!!!
I look forward to seeing the pics.
Gary & Trish
Old 08-16-2016, 08:56 PM   #17
HVrunner's Avatar
We purchased a new 2015 MBS 24R this spring. I had a pole building built to keep it out of the sun and weather. The building is 26 x 36 with a 14 x 16 OH door. The gravel drive to the side is next to my septic where I have added a dump station. The building is not finished yet. It will have a concrete floor and a man door. If I ever decide to get a larger RV I reserved space at the back to expand.Click image for larger version
Name:	ImageUploadedByForest River Forums1471395395.157327.jpg
2015 Forester 2401R MBS
HVrunner is offline   Reply With Quote
