Old 10-05-2016, 08:28 AM   #11
You are missing a key piece of equipment. You also need a 150 Ft lb torque wrench. Home Depot has one at a reasonable price. Impact wrenches are fine for getting wheels off but not for putting them back. Check the torque rating for the size wheel stud and torque to that in steps. My number is written inside the coach compartment where I keep the bottle jack and some blocking. I did both dual wheels when I put on the valve stem extenders all units also need.
nothermark is offline   Reply With Quote
Old 10-05-2016, 08:24 PM   #12
Send a message via AIM to NoviBill
Comments from he loyal opposition...
I am in good health and relatively fit and am not bad with a wrench. I purposely do not carry the equipment required to change a tire because it would tempt me to do it.
Lots can go wrong both as you are changing the tire and if you don't tighten to spec it gets worse...
My two cents: If you are highly mechanical and already own the right equipment for other work, go ahead. If you are an office worker who can turn a wrench but don't really have the background (me) leave it to a someone who does it well (worst case is you have to campout for another night ).
Bill & Renee from Novi, Michigan
2006 Lexington 255DS
http://anunbalancedbalance.blogspot.com/
NoviBill is offline   Reply With Quote
Old 10-05-2016, 08:28 PM   #13
Originally Posted by grumpy0374 View Post
Davidjeff, I think you may be a bit disappointed in the Ryobi with only 300 ft lbs of torque. The Kobalt corded has 350 ft lbs, and does an adaquate job. Dewalt also has a 350 ft lb corded wrench. And the Kobalt 24 volt battery 1/2 inch has around 600 ft lb rating. I'm not saying they are the best, just the most powerful, and its better to get the most powerful from the start, rather than spend money on something that may or may not be adaquate.
300 ft lb may or may not do a proper job of taking the lug nuts off and then back on. Hope I'm wrong, but it may not have the power needed to do a proper job.
Grumpy
Upon more thinking I went and purchased one of the Kobalts you spoke of, at 650 ft lbs and only $249 with battery, charger, tool and bag it's a real bargain, guess the Ryobi will be relegated to home stuff
Davidjeff is offline   Reply With Quote
Old 10-05-2016, 08:47 PM   #14
knockando's Avatar
You know I was just starting to think the same thing! Roadside assistance should be good (until I drive to Alaska). Thanks for all the great responses, this is such a great place for second year rv'r.
knockando is offline   Reply With Quote
Old 10-05-2016, 08:53 PM   #15
I carry State Farm on the MH and for pennies less than $1 a month I have roadside, lockout,towing (unlimited), fuel, jump starts etc... we also have AAA covering the same cause my DW travels a lot in here job. I still personally want to be prepared in case I don't have time or cell service etc... for tire replacement.
Old 10-06-2016, 05:46 AM   #16
grumpy0374's Avatar
To each his own.
But, be aware, you might be sitting, waiting for hours on the side of a road waiting for roadside assistance. And, if you have roadside assistance, check with them as to their policy about getting the right help to you. Many companies that respond to a call WILL NOT change a the inner dual tire if it is the one thats blown. And if you don't have a spare tire, you are at the mercy of the company and what they charge for bringing you a tire.
If your physically able too, and have the proper tools, you can be on your way in around 1/2 hour. It's not rocket science, and just like changing the tire on your car, just a bit bigger and heavier. As to tightening it to "spec"...its a steel wheel. I've always just used my electric impact wrench to tighten the lugs down. Unless you keep cranking/impacting after their tight, your not going to overtighten them. Your reading too much between the lines as to what you need. Just simple basic equipment.
And, for info, I'm 66 years old and still able to, and will not hesitate to change my flat if I have one, nor will I hesitate to help someone else.
Grumpy
Steve & Cheryl + Charlie & Casey, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
Old 10-06-2016, 07:05 AM   #17
I carry the tools because I might not want to wait or might not be able to get help to where I am. All the road services have limits.
I carry a torque wrench because getting caught up in the power wrench race results in bent rotors and broken studs. BTDT.
Old 10-06-2016, 07:13 AM   #18
geeman53's Avatar
We've got a 20 ton bottle jack that does the job.
2016 sunseeker 2250slec
1988 Jayco p.u.,Coleman Plantation p.u.,1989 Jayco class c, Coachman TT,1995 Little Eddie fthwheel,2007 Heartland Sundance 2500 lS fthwheel
geeman53 is offline   Reply With Quote
Old 10-07-2016, 11:26 PM   #19
I also finish tightening with a torque wrench as well, the power tool helps run the stabilizers up/down and help get lug nuts off and back on snug to use the t/w
Old 10-08-2016, 07:51 AM   #20
grumpy0374's Avatar
In a perfect situation, or with aluminum rims, I could see using a torque wrench.
In reality, when was the last time you saw a tire company using a torque wrench to mount a set of steel rims, especially on a heavy duty E-450 with steel rims. They don't. I could just imagine them checking torque on 32 seperate lug nuts. Aside from that, they use air impact wrenches that are a heck of a lot more powerful than the electric wrench I carry.
Unless you really continue to crank down with an electric impact or a manual breaker bar your not going to break a stud or warp a steel rim.
Also, if I'm on the side of a roadway, changing a flat, last thing I'm going to worry about is checking the torque on the lug nuts.
On our two Subies or Mustang with alloy rims, yes, I do use a torque wrench.
Real world, on our Lexi, I have had my rims off a number of times, either to replace my shocks, mount new steel valve stems, and to rotate the 6 tires on my rig. Always used the impact wrench, and have never stripped or broken a lug nut or wheel stud.
Grumpy
class c, tire
