Old 03-12-2019, 02:23 PM   #1
Changing rear steel wheels
Newbie here trying to figure out "where" to post a question have tried couple of other places but with limited feedback don't think the topic is that difficult. Wondering if anyone that has the 4x factory option aluminum wheels has replaced the 2x steel inner wheels with comparable aluminum wheels ? If so, what was the source of the 2x replacement aluminum wheels - Dynamax ? chassis maker ? wheel manufacturer ? Did you encounter any unexpected problems or issues installing the new aluminum wheels ( I have received 1x comment regarding "checking the stud length to compensate for thicker aluminum wheels" ) ? Any problems or issues afterwards with the new inner aluminum wheels ? Thanks again for your feedback.
camperpapa is offline   Reply With Quote
Old 03-12-2019, 02:37 PM   #2
alsdas88's Avatar
Most will not change those inner wheels due to the amount of damage that happens to the wheel surface in those inner rim areas. The road grit and rock pelting will destroy an expensive set of aluminum rims and they won't be able to be used in the exterior position due to the ugliness.
Alan
2012 Ram 3500 DRW Crew Cab, 6.7 HO Cummins
2014 Columbus M-340RK
'69 Chevy C-10, 396BB
alsdas88 is offline   Reply With Quote
wheel
