Old 05-10-2018, 07:30 AM   #1
huckranch's Avatar
Charging battery on Jeep toad
Getting ready to start towing the Jeep Wrangler 2013. Bought a rvi3brake and will be running it straight off the Jeep battery. My question is-can I run a charge wire straight from the hot pin on mh to the battery or do I have to run it through a trickle charger? Also, will I have to ground Jeep to mh? I assume itís already grounded thru hitch but just wanted to be sure.
Curt and Kathy
2016 Forester 3051s
2016 Kawasaki Teryx T4
2013 Jeep Wrangler Sahara
huckranch is offline   Reply With Quote
Old 05-10-2018, 08:14 AM   #2
You have to ground the cable from the 7 way to the jeep chassis...all I did was run the charge cable (always hot on my 335) to the battery positive terminal through a 20 amp circuit breaker. If you are anal, you can put a diode in the charge line as well.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 05-10-2018, 09:30 AM   #3
huckranch's Avatar
Thanks!
Curt and Kathy
2016 Forester 3051s
Old 05-11-2018, 08:14 AM   #4
CZNEDY's Avatar
We tow our Jeep TJ and only have the 7-wire to 4-wire harness connected from the Motorhome to the Jeep for the lights. I plug the Brake (Blue Ox) into the Aux 12 VDC on the dash. I have towed the Jeep for up to 10 hours and it starts every time. I just have to make a point to remember to always start it up and run it for a while at the end of each day.
2018 BERKSHIRE 34 QS
2016 Jeep Wrangler 75th and a
Cooler full of good ideas
Days Camped, Not Enough
CZNEDY is offline   Reply With Quote
Old 05-11-2018, 12:32 PM   #5
I use the same system for 2005 Liberty. Have never needed to use a charge wire to the Jeep.
Do you have a problem with a low charge battery at the end of the day?
I unplug the rvi at the end of each day.
Pat
2017 Isata 5
Whalenss is offline   Reply With Quote
Old 05-11-2018, 05:54 PM   #6
We installed an RVI Brake battery tender on our Jeep toad. Easy install and was wired to the hot pin. On our TV, the 12 volt feed activated with the ignition. Our last trip was 4 days and 1,600 miles. The battery was fully charged when we arrived. Never had to start the Jeep for the trip.
One other note. Our Jeep cigarette lighter came on with the Jeep ignition switch. A Jeep tech explained that Jeep has a vacant fuse slot adjoining the lighter fuse. Removing the fuse and moving it over to the vacant slot makes the cigarette lighter always active.
PenJoe is offline   Reply With Quote
Old 05-11-2018, 08:49 PM   #7
huckranch's Avatar
Actually havenít pulled the Jeep yet. Still getting it set up, but we are headed out next week so Iíll be updating this when we get back.
Curt and Kathy
2016 Forester 3051s
Old 05-12-2018, 07:01 AM   #8
I also tow a Jeep and installed an auxiliary 12v outlet on the sidewall next to my left leg. This for my Brake Buddy. It runs directly to the battery so I can keep the ignition off. I also use a Toad Charge from LSL Products.net to keep my Jeep battery charged. I have used it for several years now and it works. A little pricey but does the job.
2016 Pursuit 33BH,
2012 Jeep Wrangler,
2013 Honda 50CH
Blue OX
cberlanga is offline   Reply With Quote
Old 05-12-2018, 07:15 AM   #9
Steeljag's Avatar
X 2 !
1930 lbs CCC
2014 Jeep Rubicon JK
Steeljag is offline   Reply With Quote
Old 05-12-2018, 08:47 AM   #10
huckranch's Avatar
[QUOTE=cberlanga;1807083]I also tow a Jeep and installed an auxiliary 12v outlet on the sidewall next to my left leg. This for my Brake Buddy. It runs directly to the battery so I can keep the ignition off. I also use a Toad Charge from LSL Products.net to keep my Jeep battery charged. I have used it for several years now and it works. A little pricey but does the job.[/
Whatís the advantage of the charger? Will the hot wire from the Mh keep it charged? I know folks do it both ways Iím just not sure what purpose the charger serves.
Curt and Kathy
2016 Forester 3051s
Old 05-12-2018, 08:50 AM   #11
huckranch's Avatar
What year is your Jeep? I just tried swapping that fuse slot and thatís the outlet back by the tailgate not on the dash. Maybe they changed the wiring🤨
Curt and Kathy
2016 Forester 3051s
Old 05-12-2018, 09:19 AM   #12
It regulates and protects the Toad battery. Quick disconnect and you can monitor what itís doing when connected. Itís a personal preference.
Old 05-12-2018, 09:28 AM   #13
[QUOTE=huckranch;1807170]
Ignition on or ignition off, there is always a parasitic draw on the battery. The braking system also draws on the toad battery. And the toad battery must always be available for the break-away system to work. Hence, a battery tender on the toad with a 12v supply from the TV taking the place of the toad alternator. When getting to the destination, the toad battery is ready to go.
battery, charging, toad
